Modular V10 (6.8l)
missing
Old Mar 17, 2012 | 06:06 PM
CPaulsen's Avatar
CPaulsen
missing
Pulled my 5th wheel over the mountain.2001 F350....V10......started pinging really bad and missing. Down to 35mph in 2nd just to keep going. Got home....scanned it.....showed it had a miss fire on 5 cylinders. This is with new plugs and boots about 6 months ago. Has been running great. Cleared the codes...did a test drive....showed miss fire on 5...6...and 10......cleared again...another test drive...showed misfire on 5 and 6....checked the plugs and installed new coils and boots....same misfire again on another drive. Any ideas?
Old Mar 25, 2012 | 05:55 AM
CPaulsen's Avatar
CPaulsen
Guess nobody had any suggestions. Pulled #5 plug....it was almost completly apart. Only been in there for a month(motorcraft plugs also).Checked compression....40# in #5. Pulled head....burnt valve. And this after having both heads off last month....burnt valve on #4. Redid all valves and seats.Put all steel inserts in the heads and then came this problem. Must be a low fuel pressure problem. Have to find out why!!
Old Mar 25, 2012 | 08:39 AM
samsdad02's Avatar
samsdad02
any symptoms before this? low power, high fuel consumption etc?
Old Mar 25, 2012 | 10:37 AM
critterf1's Avatar
critterf1
Have you checked fuel pressure to see what you have? How about vacuum leaks around this cylinder? Injector functioning properly?
Old Mar 25, 2012 | 11:31 AM
jh818's Avatar
jh818
How about your injector?
Old Mar 26, 2012 | 03:30 AM
CPaulsen's Avatar
CPaulsen
Only symptoms I had was heading up the mountain and it started to ping....then got really loud most likely before the plug went.
Have to get it running and find out if its an injector,MAF,IAT.fuel pump,??? Has 117K on it.
Old Apr 6, 2012 | 05:20 AM
CPaulsen's Avatar
CPaulsen
Update....pulled the passenger side head....#5 valve was stretched .70. Checked the head again...looked like low fuel problem.Seafoamed the injectors/cleaned fuel rails and replaced the MAF sensor just cause. Runs ok now.....gonna hook onto the 5th wheel this weekend and hit the mountain grade for a test run.Will see what happens.
Old Apr 6, 2012 | 07:07 AM
TrdLtly's Avatar
TrdLtly
TreadLightly
I just replaced my engine because my #5 cyl had low compression in my 2002 with 154k mi on it. I wonder if #5 is a weak spot?
Thanks for the update.
Old Apr 8, 2012 | 10:43 PM
V10ZILLA's Avatar
V10ZILLA
I would check/replace the injectors. They would also through codes as well.
Old Apr 9, 2012 | 03:52 AM
CPaulsen's Avatar
CPaulsen
Pulled the 5th wheel about 12 miles for a test....with 9500 lbs. back there I thought it would tell me something. On 2 of the steepest grades had a slight ping for a few seconds. I am running 87 octane gas right now and will try 89 and see if that works.Going without towing you hear nothing.
Old Apr 13, 2012 | 06:42 AM
samsdad02's Avatar
samsdad02
I don't understand why a burnt valve would affect anything. Is it just carbon build up? Is it overheated from leaning out and stretches the stem?
Burniestanley
1997 - 2003 F150
Jan 25, 2019 10:21 AM
CWorthington09
1983 - 2012 Ranger & B-Series
Feb 15, 2018 12:07 PM
300FOREVER
Jan 31, 2011 08:39 PM
thosfsull
Modular V8 (4.6L, 5.4L)
Aug 29, 2010 12:07 PM
msmmce1
Sep 23, 2008 11:30 AM
