Rust through paint.
As a word of caution, before jumping on the rust conversion bandwagon, be advised that some epoxy primers are not compatible. You're basically spraying an acid on the metal surface, and in some cases they will indeed react months after paint application, causing lifting/delamination issues. I would suggest to figure out what primer you will be using and then see if it is compatible with these conversion coatings. If not, you'll need to re-think your strategy. I suggest starting with identifying the paint first, as Ospho, Picklex, etc are less forthcoming in putting out this info. Paint manufacturer's will be more up front about what their products are compatible with. Nice to know up front, as pricey as paint products are...
Product Lines
I have found it to be a very quality product, and the price is right. They also have a forum with some very interesting info;
SPI User Forums
You can read more about their primer and other things there.
And this is an absolute must read;
Perfect Paint Job
Good luck and post some pictures of your progress.
