10.25 spring width etc
Old Mar 16, 2012 | 06:05 PM
nwebbe1079's Avatar
nwebbe1079
hey guys got a few questions...
ive got a 96 3/4 ton 7.3 2wd, with an open 4.10 rear end, also have a 92 1 ton 4x4 with 3.55s, id like to put the higher gears in my daily driver before i part out the rest of the 1 ton. just wondering if the width of the springs, spring perches, etc should all be the same, I use this truck for towing alot so the heavier 1 ton spring and shocks would be nice. Right now i dont have access too the 1 ton at the moment because the base hobby shop where its stored is closed untill tommorow morning. thanks for any help ya'll can give me.
Old Mar 16, 2012 | 06:57 PM
444dieselrod's Avatar
444dieselrod
should be the same, is the 1 Ton a dually? I know the cab and chassis trucks had a narrower frame but I thought the 1 Tons used the same pearch width.
Diesel Rod
Old Mar 16, 2012 | 07:05 PM
nwebbe1079's Avatar
nwebbe1079
no its a srw, i was figuring they would be the same i just wanted to make sure
Old Mar 16, 2012 | 07:09 PM
444dieselrod
SRW will for sure be that exact width. does the '92 have the speed sensor on the rear pumpkin? cant remember if they had it there or the trans tail shaft.
Diesel Rod
Old Mar 16, 2012 | 07:14 PM
nwebbe1079's Avatar
nwebbe1079
yes it does plug looks the same as my 96
Old Mar 16, 2012 | 08:19 PM
444dieselrod
Then it should be a bolt in deal.
IHpuller450
Oct 4, 2016 11:23 AM
bernette
1947 and Older Ford Trucks
Nov 29, 2015 07:46 PM
jrockdiddy
Mar 26, 2013 11:39 AM
rcav8or
Apr 4, 2012 12:23 AM
Green Streak
Mar 18, 2004 03:29 PM
