ive got a 96 3/4 ton 7.3 2wd, with an open 4.10 rear end, also have a 92 1 ton 4x4 with 3.55s, id like to put the higher gears in my daily driver before i part out the rest of the 1 ton. just wondering if the width of the springs, spring perches, etc should all be the same, I use this truck for towing alot so the heavier 1 ton spring and shocks would be nice. Right now i dont have access too the 1 ton at the moment because the base hobby shop where its stored is closed untill tommorow morning. thanks for any help ya'll can give me.
SRW will for sure be that exact width. does the '92 have the speed sensor on the rear pumpkin? cant remember if they had it there or the trans tail shaft.
