scanguage II installed, have ?
Yes as mentioned above you already have fWT in SGII
On the CMP/CKP sensors showing sync you have the wrong X-Gauge CODE
If you truely had no sync between CMP/CKP sensors the truck wouldnt Start at all
try these codes
SYC
Crankshaft Position Sensor TXD: 07E02209CD RXF: 0462050906CD RXD: 3000 MTH: 000100010000 NAM: SYC
SYC Camshaft & Crankshaft in sync (1 = in sync) (AlternTXD: 07E02209CD RXF: 0462050906CD RXD: 3001 MTH: 000100010000 NAM: SYC
If these codes dont work talk toAmdriven2liv (Sean) has been keeping up with all the SGII codes so he would be a Great Guy to ask
Therre is also a code for FICM Sync do you have that one?????
thanks for the updates i'll try them. and no I dont have the ficm sync,I got the other ficm ones though, I got my codes from this link I found on here.
https://www.ford-trucks.com/forums/1...l#post10227382
fixxxer-upper
12-27-2011 07:22 PM
reamer
08-03-2005 06:21 PM
