Safe to drive?
Old Mar 15, 2012 | 09:57 PM
Adam Culp's Avatar
Adam Culp
Safe to drive?
Background here. 2006 f350 psd. I returned home this evening to notice a dark puddle on my concrete. I had a come home earlier and let the truck sit before leaving. I have now found that the degass bottle has burst out fluid. I am not sure what. Doest the coolant in this truck smell and taste different that typicall antifreeze ? To me it smells like terpintine. It's really greasy. It does not seem creamy at all. My question is is this a sign of a egr or oil cooler failure? I also have a horrible diesel smell in the cab when sitting with the vent system on.z not sure what to do here. Any help please!
Old Mar 15, 2012 | 11:47 PM
BLADE35's Avatar
BLADE35
Well if the Coolant bottle has Oil or Choclate milkshake in it the Oil Cooler has Blew out
If the above is true^^^^^^ DO NOT DRIVE IT or START IT for that matter
The Diesel Exhaust Smell in the Cab it from a Cracked uppipe Flex Joint or Exhaust leak
Need to replace the uppipes that come off the exhaust manafolds and go up to turbo ypipe
Unrealo4's Avatar
Unrealo4
Does the coolant look like choclate pudding? You could have a very serious problem here. Dont start or drive it until you have determinded what it is.
Old Mar 15, 2012 | 11:48 PM
Unrealo4's Avatar
Unrealo4
Damn blade you beat me by a millisecond.
Old Mar 15, 2012 | 11:52 PM
BLADE35's Avatar
BLADE35
But I assume since you said turpintine smell in coolant then its diesel fuel in the coolant
If so you need new Heads cuz injector cups are leaking or head is cracked
You threw a wrench into the Gears By saying Greasy and Turpintine smell so it could go either way.
So you must verify whats in the coolant bottle Neither option is cheap
Old Mar 15, 2012 | 11:57 PM
BLADE35's Avatar
BLADE35
Holy Smokes Jim you wasnt kidding
Old Mar 16, 2012 | 12:18 AM
Snuggyworm's Avatar
Snuggyworm
the guys are right on there.
Old Mar 16, 2012 | 06:18 AM
Adam Culp's Avatar
Adam Culp
I think it may be diesel. There is no smoke coming out of the exhaust. The coolant has no antifreeze smell what so ever. It also does not look like chocolate pudding.
Old Mar 16, 2012 | 06:20 AM
Adam Culp's Avatar
Adam Culp
I am assuming if it diesel, it would not cause any damage to drive it 5 min to the fords shop?
Old Mar 16, 2012 | 06:52 AM
bismic's Avatar
bismic
If it is diesel i the coolant, you need a new head or heads. I don't think I would drive it if it were mine.
Old Mar 16, 2012 | 07:19 AM
critterf1's Avatar
critterf1
Have it towed before you cause more damage.
Old Mar 16, 2012 | 10:30 AM
BLADE35's Avatar
BLADE35
If its a short drive I woould go for it since its Diesel fuel just drain some coolant down to little under low mark on coolant bottle
F350NewbieGirl
Feb 8, 2017 08:30 PM
Big Dually
Jan 25, 2012 06:12 PM
tramp
Jul 30, 2010 08:31 PM
Champdog21
Nov 3, 2008 09:16 AM
billssp88
Sep 8, 2006 06:10 AM
