Sponsored by: Real Truck
remove tailgate hinge?
Old Mar 15, 2012 | 09:33 PM
cbzdel's Avatar
cbzdel
Is there an easy way to get off the divers side tailgate hinge? Maybe I just need a better torx wrench? I had one that fit in my tool box and it broke when I tried to use it.. What size wrench do I need? I get my new 2008+ tailgate tomorrow and this is preventing me from installing it already haha.
Old Mar 16, 2012 | 12:08 AM
richsoucie's Avatar
richsoucie
torx plus 45 just like the bed bolts
Old Mar 16, 2012 | 07:13 PM
Fordfanatic4life's Avatar
Fordfanatic4life
put the Torx bit into the bolt, and give it a few really good wacks with a hammer to "shock" the threads..
then use a big prybar with a socket to break it loose.. or use a impact gun.
then can be stubborn to get loose on an older truck. just be sure the torx bit is fully seated you do not want it to strip out..
Old Mar 16, 2012 | 08:32 PM
cbzdel's Avatar
cbzdel
Well I stripped them both, I used pb blaster soaking for a half hour.. Tried a small rachet, nothing... Went to a breaker bar, nothing, went to the impact, fail! Both stripped within about 5 seconds.. So I got my drill charging so I can drill them out, then I will get a new nut bracket and bolts tomorrow..
Old Mar 16, 2012 | 08:38 PM
richsoucie's Avatar
richsoucie
to bad your not closer i have two that im not using also have three 1/2" drive TP45 sockets
Old Mar 16, 2012 | 09:45 PM
Fordfanatic4life
thats a shame, once it strips it def. becomes more work..
sounds like you'll get it sorted thou.
ktm4012
Aug 1, 2016 05:59 PM
1974 f100
Apr 7, 2015 09:20 PM
cbass139
Jul 9, 2010 02:01 PM
Marc150
May 3, 2005 11:24 AM
Big Red Stroker
Apr 17, 2005 11:55 AM
