Problems with trans install
Old Mar 17, 2012 | 10:15 AM
xjpilot's Avatar
xjpilot
We (at least I do) need a short summary of what you are doing. You are taking a 4x4 c6 equipped truck, and installing everything in a 4x2 frame because your old 4x4 truck had a bad frame?
Bingo, bad frame
Old Mar 17, 2012 | 10:21 AM
86fordtruck's Avatar
86fordtruck
Do you still have the old frame? If so, you can measure exactly where the trans crossmember holes are in each to see if they might be in slightly different locations? Just a thought. Good luck.
Old Mar 17, 2012 | 10:37 AM
xjpilot's Avatar
xjpilot
I do, but its in Massachusetts while I'm in Dallas. I may he able to have my mom measure it though
Old Mar 17, 2012 | 11:01 AM
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
Ok, here is a picture of the bottom of the right frame rail from the 1990 F250 parts truck. On the left is the hole for the E4OD crossmember, on the right are the two close together holes that are for shorter transmissions.
Old Mar 17, 2012 | 01:49 PM
Franklin2's Avatar
Franklin2
The two closer together holes are what I used. The one to the front was for the c6, and the one about a inch to the rear lined up with the zf. That's when I had to use the upper wings from the donor truck.
Old Mar 17, 2012 | 05:31 PM
85lebaront2
The original upper "wings" on mine were asymmetric like they could be used for either location, and before I installed the E4OD, I tried the crossmember in the other set of holes, and by reversing the wings they fit fine that way. here is a picture of my left side frame rail after putting nuts on the upper bolts so they won't rattle.
GoldCo
Nov 15, 2016 12:51 PM
youngone1234
Sep 24, 2014 12:11 AM
xjpilot
Mar 9, 2012 03:54 PM
nickhonea
Oct 17, 2008 10:46 AM
GeneStoner
Jan 12, 2003 06:14 PM
