Which ATF Fluid?
Old Mar 16, 2012 | 11:42 AM
TrdLtly's Avatar
TrdLtly
TreadLightly
Originally Posted by kevin.ford-trucks
Hey, but at the end of the day, I'm just asking what fluid I should use in my next change. I used Castrol Domestic Multi-Vehicle last time around. I just want to make sure what I put in this time is agreeable. I do plan to drain both pan and TC, but still don't want to be mixing "baking soda and vinegar".
Understood. Adding the wrong fluid could be an expensive lesson and one that I would not want to make even if the outdated owners manual said something contrary to what updated Ford TSB says.
Old Mar 16, 2012 | 12:04 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
This is how you do it, this is the fluid you use...
It's easy to find and not ridiculously expensive...
Ford Truck Enthusiasts Forums - View Single Post - What did you do to the X today?
Old Mar 16, 2012 | 12:50 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I recommend MERCON V. Any brand, your choice. Also your choice whether or not to use conventional, blend, or full synthetic. They are all available.
Old Mar 16, 2012 | 03:20 PM
Stewart_H's Avatar
Stewart_H
Mark - so what should I use in my 2000 V10 Excursion?
Originally Posted by Stewart_H
Mercon V is what you want.
Originally Posted by Mark Kovalsky
MERCON V was changed in 2006 to be compatible with all transmissions that used MERCON.
Stewart
Old Mar 16, 2012 | 03:21 PM
Stewart_H's Avatar
Stewart_H
Originally Posted by TrdLtly
Hey Stewart, What about fluids that say that they are compatible with Mercon V? Are those safe to use on the 4R's and 5R's?
NEVER use MERCON V in a 5R110 transmission. It will kill all seven solenoids, and you don't want to know what it cost to replace all of them.
Scott, when I answered your question, I didn't see where you had included the 5R in your question, sorry.
Stewart
Old Mar 17, 2012 | 08:13 AM
Excursion4X4's Avatar
Excursion4X4
[QUOTE=Mark Kovalsky;11581729]NEVER use MERCON V in a 5R110 transmission. It will kill all seven solenoids, and you don't want to know what it cost to replace all of them.
ok..clear as mud now! What goes into the 5r then?
Old Mar 17, 2012 | 08:21 AM
TrdLtly's Avatar
TrdLtly
TreadLightly
[QUOTE=Excursion4X4;11585839]
https://www.ford-trucks.com/forums/1...l#post11581819
Old Mar 17, 2012 | 01:09 PM
Stewart_H's Avatar
Stewart_H
Mercon SP has always been the trans fluid to use in the 5R.
Stewart
Old Mar 17, 2012 | 02:46 PM
Mark Kovalsky
MERCON LV is now replacing MERCON SP.
Old Mar 17, 2012 | 02:48 PM
Stewart_H's Avatar
Stewart_H
LOL, doncha love upgrades!
Do you know if Ford has issued a TSB for that yet, Mark?
Stewart
Old Mar 18, 2012 | 08:13 AM
tdappleman's Avatar
tdappleman
Mark - question on what type of fluid you use? Brand and syn vs. conventional? Thanks again for your participation on these boards!!
Old Mar 18, 2012 | 08:18 AM
Mark Kovalsky
When I had a 4R100 and used it for towing I used Mobil 1 synthetic ATF.
Old Mar 18, 2012 | 08:39 AM
  #28
tdappleman's Avatar
tdappleman
Thanks! That's exactly what I was planning to use when I get my truck back from the shop. It currently has Amsoil ATF and I'm hoping that didn't contribute to the failure I had - only been in there about 25k miles.
Old Mar 18, 2012 | 08:49 AM
  #29
Mark Kovalsky
I've talked to several master mechanics that really like for people to use Amsoil in everything. They won't sell it, they just like people to use it. It's paid for several kid's college educations.
Old Mar 18, 2012 | 09:28 AM
  #30
Mark Kovalsky
Stewart
I don't know.
