valve cover gaskets
Old Mar 15, 2012 | 03:16 PM
66crawler's Avatar
66crawler
valve cover gaskets
What are the best ones to use? Cork or rubber? Motor is a 390 and the PO put on some chrome cheapos when he put the motor together and the passenger side leaks a bit and it runs down the header tube so I have a wonderful oil burning smell for the first 30min of a drive :/.
Old Mar 15, 2012 | 04:41 PM
Beechkid's Avatar
Beechkid
I prefer cork....use silicone glue on the valve cover side (since it is proably uneven)...this makes it easy to install, remove cover, adjust valves and re-install too.
Old Mar 15, 2012 | 05:02 PM
66crawler's Avatar
66crawler
Do you know the felpro part number for cork? All I found was rubber :/
Old Mar 15, 2012 | 05:04 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Cork should use the same part number, minus the "R" at the tailend.
Old Mar 15, 2012 | 05:13 PM
66crawler's Avatar
66crawler
Ok cool, thanks a lot bro
Old Mar 15, 2012 | 05:19 PM
69cj's Avatar
69cj
I've had problems with the rubber and steel core rubber gaskets. My vote is for cork.
Old Mar 15, 2012 | 07:11 PM
critterf1's Avatar
critterf1
Cork all the way.
Old Mar 15, 2012 | 10:14 PM
puttster's Avatar
puttster
The beech is right
Cork lightly glued to the VC, then some grease on the other side and you can take the covers on and off easily thereafter, if you don't crush th ecork with the bolts. Different valve covers have different sized slots to hold the ears of the gasket. On some (I think the Power by Ford ones) the cork gaskets fit perfectly, everything is great.
On mine the slots were smaller so I used rubber gaskets and razor bladed the ears a little so they would fit into the slots. No glue on rubber, so far, so good!
puttster
Old Mar 15, 2012 | 10:28 PM
66crawler's Avatar
66crawler
I have sone cheapo chrome ones on there right now and I pulled one side off, 2 of the holes were mushroomed so I flattened those out and stuck the gasket back on with silicone to the valve cover. This is only temporary unroll I can get the cork ones.
Old Mar 16, 2012 | 08:48 AM
69cj's Avatar
69cj
On the bottom side of the gasket I rtv'd both sides. Valve covers are no fun on a 428cj in a mustang.
Old Mar 16, 2012 | 08:55 AM
Rogue_Wulff
Cheap chrome covers can be the hardest to keep sealed. Often, the slots for holding the gaskets either aren't there or not quite the right size. The profile of the metal where the gasket sits may not be the same as the factory covers, allowing the gasket to slip when the bolts are tightened down. The metal can also be a thinner guage material, letting the covers flex between the bolt holes, or deform around the bolt holes.
These reasons are why I stick with the factory covers, or go with a good set of cast aluminum covers.
Old Mar 16, 2012 | 04:17 PM
66crawler's Avatar
66crawler
I would love some fabricated covers but there expensive lol, I think ill hit up the SWAT meet next month
Old Mar 16, 2012 | 06:45 PM
66crawler's Avatar
66crawler
Thanks everyone for there input, I got some cork gaskets then siliconed them to the valve covers and put some grease on the head side. So far no leaks .
Brnfree
May 25, 2017 03:32 PM
DutchmanAZ
18
Sep 19, 2014 01:32 PM
80351
Maryland Chapter
Jun 17, 2010 08:34 AM
ghreds
May 10, 2008 01:44 AM
greghoffmann
Jul 17, 2001 03:02 AM
