Sponsored by: Real Truck
Brake and steering issues, please help!
Old Mar 15, 2012 | 02:55 PM
CrewCabLongbox's Avatar
CrewCabLongbox
Hey guys, I know that when buying an older truck there are things that will be in need of repair, which I am perfectly fine with. However, I was just wondering what the fixes are to my two main issues. First is that my steering feels loose, with about two inches of steering wheel play when held on center. However, when cornering all feels tight and rigid, is there some adjustment I can do? Secondly is a sinking brake pedal. I get good pressure when the pedal is about halfway down, but until then it feels very squishy. I had the brakes bled by a buddy who is a mechanic, I also have new pads and the fluid level is proper. Is a new master cylinder needed? Thanks guys!
Old Mar 17, 2012 | 11:07 AM
CrewCabLongbox
Anyone have any ideas?
Old Mar 17, 2012 | 02:49 PM
dchamberlain's Avatar
dchamberlain
Steering. You'll need a buddy.
First, have someone move the wheel back and forth about 1/2 turn with the engine running and wheels on the ground while you look at everything underneath the front that moves. Look at all the tie rod ends. There should be no play at all. Look at the track bar ends also.
Second, get each front wheel off of the ground. Use at minimum a 4 ton, but better a 6 ton jack stand for safety. Have your buddy reef up and down on the tire as hard as he can while you watch the upper and lower ball joints and the hub. Again, there should be no play.
Brakes are harder. They can be really hard to bleed, so you might try having it done again. Are you losing any brake fluid?
Old Mar 17, 2012 | 07:31 PM
Boris2000's Avatar
Boris2000
Redhead rebuilt gear box. Took care of my steering problems.
Old Mar 17, 2012 | 08:54 PM
CrewCabLongbox
Have already checked the entire chassis, first thing I did actually, but thank you for the tip. I can live with it, but it's annoying...is it necessary to have fixed?
Also for the brakes, the fluid is not burnt and is not leaking, master cylinder perhaps?
swamp donk
Aug 1, 2017 08:10 PM
Da_Lariat_Chariot
Apr 4, 2016 09:23 AM
mrpatrick150
19
May 19, 2011 09:55 AM
02f250fx4
1997 - 2003 F150
Oct 25, 2007 06:04 PM
Violjohn78
Feb 5, 2004 10:52 PM
