need help with a vibration
I've just recently finished the tie rod ends and steering linkage ends (inner tie rod ends in parts store speak). Now I'm going ahead with both bearing assemblies and Warn premium locking hubs.
After all this, I think I need a vanity plate with a crossed-out circle over a pile of cash...
It's worth it though- I got the truck super cheap and it does run great.
My driver side stub axle had a little bit of scarring but my passenger side was wasted.
As for the seals, the big seal (on the stub shaft, at the knuckle) is Ford part #F81Z-3254-CB, also known as SKF part #28600. I ordered mine through onestopoem.com for $38.36 each. They are cheaper at Rock Auto ($31.79), but since I was ordering stub shafts from OneStopOEM anyway, I let them have the order for these too because it evened out in shipping costs.
The smaller seal (on the inboard section of the axles that seals the axle tube) are Ford part #F81Z-1S175-HCA (alternative numbers are BR584 and 710413). I bought mine at AutoZone, I believe I used the 710413 number, and the brand was Timken, for about $18 each.
Steering Rebuild
Left Tie Rod- Moog# ES3423 (Amazon $36.91)
Right Tie Rod- Moog# DS1439 (Amazon $102.41)
Tie Rod Adjusting Sleeve- Moog# ES3422S (Amazon $16.85)
Left Steering Rod (pitman side)- Moog# ES3427T (Amazon $43.82)
Right Steering Rod- Moog# DS1438 (Amazon $93.37)
Steering Rod Sleeve- Moog# ES3426S (Amazon $16.50)
*All parts above qualified for free super-saver shipping- great deal unless you need the parts asap. Amazon's super-saver shipping was all over the map for me for shipping times- from 3 days up to 9 days.
Hub Rebuild
Hub Bearing Assemblies, not ABS- Timken# 515021 (Amazon $182.44 ea)
ACDelco 18A1494 Performance Rotor (Amazon $87.29)
ACDelco 18A1495 Performance Rotor (Amazon $87.29)
Motorcraft BRSD756 Super Duty Pads (Amazon $60.23)
Stub Shafts- Ford# 4c3z-3B387-AA (OneStopOEM $149.93 ea)
Axle U-Joints- Ford# F81Z-3249-AA (OneStopOEM $33.82)
Hub/Knuckle Seal- F81Z-3254-CB (OneStopOEM $38.36)
--alternative part #: SKF# 28600 or 710493
Axle Tube Dust Seal- F81Z-1S175-HCA
--alternative part #: BR584 or 710413 (Timken 710413- $17.99 ea, AutoZone)
Warn Premium Locking Hubs #38826 (Summit Racing $206.95)
*Again, all above parts sourced from Amazon were shipped free via their Super Saver Shipping. All the parts sourced from OneStopOEM had an additional shipping charge. Rock Auto actually comes in cheaper for the U-joints and both seals, but since they didn't seem to carry the stub shafts, the combined shipping at OneStopOEM was the cheaper way in my case.
I'm just waiting on the stub shafts, U-joints and knuckle seals to arrive, then I can put this bad boy together...
You know, I am almost sad that my ball joints weren't bad at all. NOT!!!
I searched all over the web, and OneStopOEM was about the cheapest place for the stub shafts. I chose the cheap shipping and it was still here in a couple days (could be because they are in Michigan and I'm in Indiana though).
