Sponsored by: Real Truck
Got Rear Ended
Old Mar 16, 2012 | 06:27 PM
richsoucie's Avatar
richsoucie
Originally Posted by smotrs
Was the driver yapping on his phone or something?
no one knows if she was talking or not im going to lean toward yes. she even tried to blame the accident on my sister
Old Mar 17, 2012 | 08:42 AM
fbnmark's Avatar
fbnmark
Of course it was your sisters fault, if she had NOT stopped at the stop sign she would not have been in the direct path of a vital cell phone conversation
Old Mar 28, 2012 | 05:43 PM
richsoucie's Avatar
richsoucie
sorry guys have not updated in a while i had to tear into the interior to figure out why the sunroof would not close turns out it was a broken guide on the pass side and another piece on the driver side. while i had all the pillars and headliner out i figured perfect time to install my audio system and clean the carpet so out came the seats too
put infinity reference in all four corners
no pics of the front speakers and ill have to go out and get some of the head unit subs and amp. i put the amp under the center seat it just barely fit but the seat holds it down tight and i can be assured it will not get stolen unless someone takes my seats out too. Also while i had it apart i removed the pass side window from the window lock circuit and hooked up the high idle. Now on to the sunroof it seems the part that broke on the drivers side cannot be ordered seprate from the frame assembly so off to the hardware store i went. i got some 1/4" machine keys and an 11/64th drill bit
you have to cut one of them short so it will fit into the track and i put the holes too far back the first time. also very important to only drill into it a little so the spacing for the track is correct. heres where it attaches on the sunroof frame.
not a great picture but i tried pointing to the little tabs with pliers i had to notch out the back of the machine keys to fit on the tabs
ill have to go get a picture with it back together but basically i just slid the machine keys over the tabs and put some jb weld on there with a model brush its drying right now so ill let you know how it works i dont see any reason why it wouldnt. also i replaced the guide on the pass side but the guide rod is held in with plastic clips that of course you cant undo without breaking solution was a very small metal clip think it was called a hair pin clip was in the box next to the machine keys and cotter pins at the hardware store. thats it for now its going to the frame shop friday then i gotta clean the frame and undercoat it replace my driver side backing plate and put the truck back together.
Old Mar 28, 2012 | 06:00 PM
richsoucie's Avatar
richsoucie
amp
subs
and the head unit
and the piece of the sunroof
Old Mar 28, 2012 | 06:54 PM
Gordon-0's Avatar
Gordon-0
looks good.
it can be a lot of fun doing that kind of work, as long as it is paid for by the insurance.
glad your sister is OK
did she go get checked at the hospital?
i was rear ended at about 35-40 and it knocked my radio out and on to the floor.
i had some minor back/neck pain so i went to get checked out. luckily everything worked out ok for me... mostly.
teh lady that hit me had no liscense, no insurance, and was not a legal citizen. my insurance had to cover it
EO2SeaBee
6.7L Power Stroke Diesel
75
Aug 27, 2020 08:10 PM
grinnergetter
867
Apr 16, 2020 10:31 PM
1979brandon
Sep 24, 2017 12:11 AM
wrvond
All Things Towing
17
Dec 29, 2016 07:23 PM
Muppy1840
Jan 25, 2015 08:47 AM
