injector hold down bolts
Old Mar 14, 2012 | 01:59 AM
ChunderDownUnder's Avatar
ChunderDownUnder
I need new hold down bolts. Diesel orings site has em but there are two types 39mm or 48mm. My sticks are Full Force 250/100 AA code. which one do i need
Old Mar 14, 2012 | 02:23 AM
BigAlsPSD's Avatar
BigAlsPSD
Are they the lower or the upper ones? Bob is selling the uppers P/N F4TZ 9R523 C
P/N F4TZ 9R523 A is the lower without the long shank.
Old Mar 14, 2012 | 06:29 AM
429 f-100's Avatar
429 f-100
you need 8 of each.
Old Mar 14, 2012 | 07:32 AM
stinson 108-1's Avatar
stinson 108-1
stinson 108-1
how come only the upper hold down bolt is mentioned when tightening up under the vc.
or did i miss something in those threads? i think even in the colored picture that has the rocker arm bolts and injector hold down bolts circled, there is only one. maybe i'm wrong, i'll try to find it. i plan on doing this soon.
Old Mar 14, 2012 | 10:10 AM
BadDogKuzz's Avatar
BadDogKuzz
I just did the retorque under vc and I only seen one hold down bolt for injector but there is the injector oil spouts bolt on the top side of injector. And I think there is a bolt under for injectors under the injector. I am not sure since I have yet to pull my injectors.
Chunder I think it would be best to like Wes/ 429F100 said and just replace all bolts. Better safe than sorry
Old Mar 14, 2012 | 10:48 AM
stinson 108-1
stinson 108-1
ok thanks, 1 is all you ever hear about tightening. i guess i'll find out when i open it up.
Old Mar 14, 2012 | 11:05 AM
429 f-100's Avatar
429 f-100
i just did replace my inj and did not replace the hold down bolts why are you replacing them ?
Old Mar 14, 2012 | 11:56 AM
BigAlsPSD's Avatar
BigAlsPSD
For the retorque you can't get to the upper bolt, it's partially under the injector. The injector hold down flange has an oblong teardrop shape that allows you to slide the flange up(towards the intake) and lift. You can retorque it without the injector in though.
Some break them off, some overtorque and stretch them, some do it as preventive measures. Not sure in Brian's case.
Old Mar 14, 2012 | 12:38 PM
stinson 108-1
stinson 108-1
thanks, that explains it.
Old Mar 14, 2012 | 03:30 PM
429 f-100's Avatar
429 f-100
[quote=BigAlsPSD;11573187]For the retorque you can't get to the upper bolt, it's partially under the injector. The injector hold down flange has an oblong teardrop shape that allows you to slide the flange up(towards the intake) and lift. You can retorque it without the injector in though.
all you have to do is remove the oil squirter tube one bolt and you can get to it i would check it also .
Old Mar 14, 2012 | 11:33 PM
ChunderDownUnder
my donor engine (which Im rebuilding) didnt have any. So 8 of each, right ??
https://www.ford-trucks.com/forums/1...tor-build.html
Old Mar 15, 2012 | 05:52 AM
429 f-100's Avatar
429 f-100
that is correct brian 8 of ea.
bakerbuilttracks
Feb 5, 2018 08:14 PM
jstihl
May 19, 2017 07:03 AM
Whitey Ford
15
Aug 4, 2016 07:07 PM
814fivesprings
Jul 25, 2012 12:07 PM
Schmavic
Mar 13, 2004 07:30 PM
