flathead v8 radiator clogged, best way to unclog?
Just pulled the radiator out of the 53 c600. what started out as a "just going to replace the thermostats" has turned into pulling rad. was thinking about soaking it in the wifes jetted tub but am sure there are better less deadly options. . like taking it to radiator shop to have it cleaned. how much could i expect to pay for that service? i havent even called around yet as i wasnt planning on this.
maybe i can just hose it out some bu doubt it would do anything.
Thanks, sounds reasonable. hopefully it does not need anything else. it looks pretty decent and no bent fins etc, just when looking in there after i drained it you could see all the crap clogging the thing up.
seems like i see alot of these flatheads being run without thermostats. not sure why though? any reason why i should not run thermostats in the beast after the cleaning? i would think that if the block and rad where clean then it may need the thermostats just to get hot in cooler weather?
Most people pull the thermostat when the start having a overheating problem... It helps for a short bit but then you have twice the amount to repair when you clean the radiator. I was once told by a old timer that he uses filtered water and anti freeze, he changed it regularly and never had a problem of overheating or calcium buildup from tap water.
hahaha, I sure hope not! I did ask how soon they would be done and I should have it back tommorrow. Thanks; now I'm going to be thinking about that..
My wife did get nervous when she got home last night and I was pulling the radiator out. trucks supposed to be in the St Patties Day parade on Saturday.
