We are getting ready to put a 428 in my 62 F100 4x4. I thought 59-65 frames were the same, but Summit says 62 is different from the 65 frame. Help! Thanks
The problem comes with the pre 65 Fe swap because they weren't factory. I belive you can use headers for a 66 4x4 with a 352 or a later model with a 390 but be prepared for some massaging to make them work. My 64 has Sanderson's that the PO installed bit the passenger side tubes were cut and turned to clear the starter, if your using a mini starter you should be ok.
I thought we went through all this a week or two ago.
That is what I told the Summit guy. I told him I was pretty sure the measurements are the same. So 59-64 4x4's used the same frame? I think the Sanderson shorties will be excellent.
