Sponsored by: Real Truck
Keyless entry pad not working.
Old Mar 12, 2012 | 08:29 AM
captainjohn2008's Avatar
captainjohn2008
Hi all I'm new here so be gentle. Not sure if I'm posting in right area but here goes. I have a 2008 F450 with the factory keyless entry pad on drivers door. It quit working, the 7\8 light was not lighting so on advise from an older post I removed the pad from the door, disconnected the power plug and disassembled the unit on the work bench. Cleaned the circuit board of slight corrosion on contacts then used compressed air to clean unit. Looks like new in there now. Reassembled and reinstalled unit, lights now function when pressing key pad but the locks still do not work. So my question is: since I disconnected the power does this need to be reactivated in the computer or something by dealer??? Thanks All John.
Old Mar 13, 2012 | 06:08 PM
Tonyplane's Avatar
Tonyplane
I do not have my manual in front of me, but if I recall any owner set keyless number is lost if power is disconnected and must be reset. If you have the factory setting, try that. If you do not have the factory setting, ask the dealer.
Old Mar 15, 2012 | 04:15 PM
captainjohn2008
Final update to my keypad problem. I just replaced the keypad with a new one and working great! Some electronics do need to be programed to the control module but this is not one of them. Thanks John
Masterducker
2009 - 2014 F150
Jun 14, 2013 05:58 AM
gddyup
Feb 21, 2012 07:43 AM
Suedeuno
2004 - 2008 F150
Dec 27, 2011 09:37 AM
mike838
May 2, 2008 09:02 PM
Mil1ion
Electrical Systems/Wiring
Dec 1, 2003 05:34 PM
