So what did you do to your 6.0L today?
Well.. Yes that is a deep subject.
I have the bed of the project truck a little over half way off. Not a lot of heavy lifting on my part just
a lot of walking around the truck to readjust the blocks I have under the bed. My hang up right now is
the wheels. So I can see if I can round up enough help to lift the one end or I can lift the truck up with
the floor jack. Then pop the tires off and set it on some jack stands and slide the bed off the rest of the way.
The truck looks sort of funny the way the bed is sitting on it right now.
Lookie Loos screwing up traffic.
The truck really looks funny this way. Had I know what I know now I would of extended 2 of the C channels about
12 to 15 inches more on the inside when I was welding this thing up. I could still extend them now if I wanted to and
adding some rollers to it might not hurt. Sure would make it easy to just roll it.
I had to relearn welding. it's been quite a few years sense the last time I did any MIG and it did not help having the
wrong size wire in the welder. I have 0.023 for small projects and really could of used some 0.030 for this one. Oh well
just had to make a lot of passes and crank up the feed.
More fun on Friday.
More fun on Friday.
the hood latch after marking it so it goes back in the same place. Then some high density foam that
some give to it but not too much to lay on the hump that has the Power Stroke badge on i. Your chest
will thank me for that and your belly for the hood latch.
If your doing this at home be sure to get some thing to stand on like a sheetrock bench and remove
My understanding about the Ford warrantee is that the parts will be covered for two years even for the DIY people.
You may want to call someone like Ed at FICMrepair and double check on that.
For those of you that are not clear on why I am swapping beds this photo will give you an idea about what is going on.
You can see in this photo how there is a bit more water in the center. I was able to push some of the bend up with the Port-A-Power.
But could not push it out much more than this. 20 tons of lifting force and all I did was lift the truck off the ground. And if you look
from underneath from the side you can see the rails are bowed down.
Today I did noting other than take a drive down I-5 and back to pick up this precious package.
In his coloring he is a lot like my two boys Tetsu and Mokkun that passed away in 2017. he just does not have the rosettes (spots) that a Savanah would have.
This little guy does not have a name yet and I am thinking on some. Names i won't use are Dodge,Toyota or Chevy.
I am thinking along the lines of Alexander The Great or Xander for short.
