Wrong Oil
Old Mar 11, 2012 | 09:49 AM
Vato2002's Avatar
Vato2002
Unhappy Wrong Oil
all i could get was 85/140 for my diff when i replaced the cover & gasket will i have any severe problems? i see everyone is using 75/140 ls syn i also just discovered my pinion gear seal is leaking should i just drain & refill with mobile 1 ls syn?? when i do the seal
Thanks Its a 98 F15o 4X4 8.8 Rear end
Old Mar 15, 2012 | 06:08 PM
Lou Braun's Avatar
Lou Braun
No problem with the oil that you have in the differential. When you repair the pinion seal, just replace the oil with the grade specified in your owners' manual.
The 75-140 LS synthetic is an excellent choice. If you have a posi-traction rear axle, you may have to add some extra conditioner, but I would start out with the standard LS stuff. If you have an open differential, the standard synthetic will work just fine.
Lou Braun
Old Mar 17, 2012 | 03:04 PM
Vato2002's Avatar
Vato2002
Thanks for the info will be fixing next weekend
amsk8er1983
Feb 6, 2010 08:40 PM
juneau76
Feb 9, 2009 01:00 PM
bryyce62
Feb 27, 2008 05:35 PM
67FordMustang
1997 - 2003 F150
Dec 27, 2007 10:06 PM
2shabby
Jul 27, 2004 07:35 AM
