body line
Old Mar 10, 2012 | 06:19 PM
jimford1's Avatar
jimford1
body line
I have a 68 ranger f100 shortbed bump. How can i figure out if my frame isbent. It is dropped but the guyused dropped I beams. Mini tub in the rear. I figure it might partially be cab mounts BUT shimed thecab and had to shim the bed up like 1". The bed shouldnt have to be shimmed. Cant find a frame place around Buffalo,ny that does old vehicles. Any guesses? Thanks guys!!!
Old Mar 10, 2012 | 07:15 PM
HIO Silver's Avatar
HIO Silver
It's difficult to verify with the cab on the frame but the shadetree method is to drpp string lines from frame points and measure diagonally. Each cross measurements should be less than 1/4-inch.
You can make string lines with fishing line and a small weight at the end to keep it taut. Tape them to the cab mounts, shock mounts, and other points that are replicated on each frame rail and start measuring.
GMbusa
Mar 25, 2016 02:20 PM
AlbraiNYa
16
Sep 7, 2015 07:14 AM
babyboov92c
Jul 2, 2013 12:15 AM
jimford1
Nov 28, 2009 02:29 AM
tubbedF100
May 16, 2003 01:25 PM
