Fuel Sender/Pickup
Old Mar 10, 2012 | 12:43 PM
JonathanN's Avatar
JonathanN
Fuel Sender/Pickup
I'm an SD guy so I need a little help with this '97... what exactly is in the tank? I'm not sure this truck is getting fuel. I won't know without an external gauge, but it kinda acts like this is the case. I know there's a foot... does it have a screen? How about a strainer? I know the feet like to break off. Both tanks are almost empty according to the gauge. I don't want to fill them up to see if that's the case and then wind up having to drop them anyways. I might as well drop them while they're empty... anybody have any input before I drop the tanks? I don't want to have to drop them if I don't have to. Thanks, guys!
Old Mar 10, 2012 | 12:48 PM
Ken_C's Avatar
Ken_C
people here agree that pulling the bed off is an easier way of getting to the top of the tanks. all thats in there is the pickup and its screened. and the level sender. and the pickup tubes do break and the easiest way to check if thats the case is fill em up. i would also check fuel pressure at the port on the left side of the fuel filter.
Old Mar 10, 2012 | 03:22 PM
DRRXR's Avatar
DRRXR
What Ken said.
The fuel pressure at the schrader valve should be around 45 to 65 even shimmed it should be under 75. It will swing some so triple check it to get the swing readings
Using a cheap tire gauge can roughly let you know whats happening.
All of the above plies if you still have the diaphragm fuel pump & fuel bowl and have not modded that.
Old Mar 10, 2012 | 04:30 PM
JonathanN's Avatar
JonathanN
Bowl is gone... have a Super Duty pump with pre and post-pump canister filters installed. I pulled the stuff outta the tanks and they look good, nothing but a foot and screen like you said. I didn't think to make sure the air was purged after I fired it up and it ran bad and died, almost running like it was before. After the pressure came back up (there's a gauge on the regulator), it fired up and ran pretty good. All this was after I switched to the fuller (is that the right word? ) tank... I'm thinking that some full tanks and a fuel pressure gauge (visible while driving) are in order. Thanks for the input, fellas!
Old Mar 10, 2012 | 04:34 PM
Hussler's Avatar
Hussler
But Ken, ... that spoils all the fun trying to lower an empty tank, which is never empty anyway. Breaking a strap trying to lower the tank down is fun and with 2 people and a jack, it slips, and all the wiring is ripped out of the connector and you don't have a replacement. Then you get the tank out and everything is fine, except the busted wires and strap so you have buy all that crap , put it all back together, wishing you never started the project.
Old Mar 10, 2012 | 04:38 PM
JonathanN's Avatar
JonathanN
Haha! That's funny...
Old Mar 10, 2012 | 04:39 PM
DRRXR's Avatar
DRRXR
Thumbs up
and on a more positive note Jim
We all get a extra hr to do it tomorrow or do what ever. I love having a extra hr of daylight
Old Mar 10, 2012 | 10:18 PM
oldbird1965's Avatar
oldbird1965
My 5th wheel rail are welded to the frame and also bolted. I had to do it the dirty way. Both of mine were leaking at the sending unit gasket. One had a busted cup-screen that I fixed. Anyway, it sure is great not having to guess how much fuel it would take to fill the tank and then subtracting a couple of gallons so it wouldn't leak at the top. I stick the nozzle in now and go wash the windows and let it click off. I put this awful job off for a couple of years but am now glad I did it. My neighbor even said that she has never seen me that dirty, LOL!!
vc10786
Dec 25, 2018 04:41 PM
presidentsdad
Dec 7, 2014 10:48 AM
Firemudder
May 30, 2010 07:28 PM
20024.2V-6
Mar 19, 2010 05:53 PM
ajorn
Feb 23, 2010 07:41 PM
