No fuel pressure at fuel gauge? Truck is running
So I bought the adapter and installed it and a fuel pressure gauge (mechanical) from my fuel bowl. I hooked it all up and I get no reading from the gauge. I'm also not getting pressurized fuel from the hose that I hooked up. (I used this port...
https://www.ford-trucks.com/forums/9...ure-gauge.html
Need the FTE help on this one? The only difference with the Ex is that it has a greasecar system on it? I'm sitting in the truck, as it runs writing this and the pressure gauge has no fuel going to it...help?
Ok, first, your truck will run with out fuel pressure (albeit like chit, but...) So how does your truck run? Like no problems until your gauge read no fuel pressure? Does the gauge work?
The standard type tests won't work here because you have another fuel system tied in. Need some info on "how" your grease is plumbed in. Tell us every OEM "change" to your fuel system. Then we can help.
</sigh>
Uh Yea, I wouldn't drive it as far as the end of the driveway until I knew exactly what changes were made, and how they affect the factory system. If you break down somewhere, you won't be able to get any help unless you get lucky and find someone who understands the WVO/SVO stuff.
Thats why its not working you need a grease pressure gauge!
