c6 bolt on yoke: where would i go about finding me one of these,i finnally found a c6 for divorced setup but it does not have the bolt on yoke attached. any help? thx http://i1066.photobucket.com/albums/...rdream/t2p.jpg
I'm assuming that you need the flange that connects to the driveshaft with the U-joint and then bolts to the flange in the picture.
According to the Ford parts catalog there are two possibilities. One for the 1270/1310 U-joint, the other for the 1350 U-joint
1270/1310 U-joint
B9T-4866-A
Aitkin Motor Co., Aitkin MN has 1 (218) 927-2169
Griesel Motor Co., Okarche, OK has 1 (405) 263-7242
1350 U-joint
D3TZ-4866-A
Green Sales, Cincinnati, OH has 15 (800) 543-4959
Van Cleve Ford, Morton, WA has 2 (360) 456-5999
If you want to double check and make sure it's the right flange here is the page from the Ford parts catalog giving the flange dimensions.
Click on the .pdf link to view and scroll down the page.
