Fuel pressure reading...
Old Mar 7, 2012 | 09:05 PM
BRay09's Avatar
BRay09
06 F250 6.0L 4x4
Well i got my glowshift gauges in this past weekend. Trans temp, boost, egt and an electric fuel pressure gauge. At idle its showing about 50-52 psi. Is that not low? At WOT it drops to about 48psi and then jumps back up. I notice at WOT when it shifts, the FP usually jumps to about 68-70. Is this normal? Or is this what i am to expect since i am using an electric sending unit?
Any preferences on a mechanical gauge and housing that can go safely on my cowl?
Old Mar 7, 2012 | 09:27 PM
bismic's Avatar
bismic
You really need at least 60 psig at idle IMO. FullForceDisel recommends a minimum of 50 psig for injector health.
Old Mar 7, 2012 | 09:36 PM
BRay09's Avatar
BRay09
I'll look into doing the blue spring upgrade. Is that something I need to get from Ford?
Old Mar 7, 2012 | 09:39 PM
bismic's Avatar
bismic
yes, or international
Old Mar 7, 2012 | 10:17 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Or from right here:
Riffraff Diesel: Ford Fuel Pressure Regulator Blue Spring Kit
Old Mar 7, 2012 | 10:19 PM
bismic's Avatar
bismic
I forgot about them! good catch texastech
Old Mar 7, 2012 | 10:26 PM
texastech_diesel
Token Redneck
I've been sending Clay a lot of my money lately, so he's on my mind a lot.... waiting on my EGT gauge to come in the mail!
Old Mar 7, 2012 | 10:27 PM
bismic's Avatar
bismic
yeah - I am about to replace my dieselsite boots w/ his!
Old Mar 8, 2012 | 12:31 AM
Ian123's Avatar
Ian123
Sounds like you need the blue spring update. As for the inconsistent readings, that seems to be how glowshift fuel pressure gauges are. Sometimes ill start up my truck and the gauge is pegged at 100 psi, 5 minutes later and it reads normal.
Old Mar 8, 2012 | 09:00 AM
F-250HD's Avatar
F-250HD
RIFFRAFF makes great CAC boots for the money, mine are holding up nicely.
1957F100
Apr 9, 2013 09:54 AM
garsm
Dec 14, 2011 10:11 PM
ChunderDownUnder
Sep 24, 2010 09:17 PM
Brian460
Dec 30, 2008 04:50 PM
TNT in Round Rock
Jun 11, 2006 07:48 PM
