honestly im getting really tired of dumping money into this POS!! i was going to autozone to get oil for the truck then on the way there it feels like it has NO power when i hit the gas.. does not go answer that fast thats issue 1. number 2 on my way home it felt the same almost like no power at all then i approach a stop sign idles get ruff then truck dies of me.. start it back up start going down the block next time i come to complete stock dies again.. friend said check the coil pack so i unplugged each coil pack to see if idle changes unplugged the 2nd 1 on driver side of motor idle didnt change like others did so i went to autozone again bought new coil pack put it on an pulled out my driveway an AGAIN DIED ON ME!!!! WTF????????????? honestly anyone in NYC wanna come buy this truck take it for 3800 i paid 4400 for it an im sick of this crap cause this is really pissing me off now
i scanned for codes an it said system to lean bank 1 but that was before i started changing the coil pack.. an i want to know wtf is it dying for? i drive it idles ruff then dies at a light or sign
Does the truck run rough at idle? Have you checked for vacuum leaks? Spray some starter fluid around the vacuum lines and listen for an idle change.
You don't say what vehicle you have but on the 5.4s there's a vacuum connection behind the throttle body, by the idle control motor that disintegrates over time.
I know this is not going to be met with any populairity but the first thing that needs attention is your attitude.
Second is your not willing to think about anything and third you want some one else to tell you everything.
There is not a vehichle on this planet you won't have a problem with at some point during ownership and be just as irritating to you.
Either settle down or have someone else fix it.
This WTF stuff don't fly or help solve anything.
If you want help, settle down and work with us or sell the truck and get another one of any make, and still be prone to the same things.
Flame away and good luck.
What better place could there be to vent his frustrations than online? You remind me of the guy that yelled at another guy in the bathroom for farting...
put yourself in my shoes how about that? im 23 an lost my job few months back an bought a truck that was suppose to be fine that just needs MORE MONEY on top of what i paid for it!
Cleaned the iac with carb cleaner used a lot an cleaned it good an still same thing. Idle is hard an ruff went down my block an it started sputtering ! Wtf?!?
I had the same thing on my 5.4 f250 it was the vacuum hose behind the throttle body was cracked it was like $75 from ford but no parts store sells it good luck
