Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
My Escape registration wrong
Old Mar 7, 2012 | 05:08 PM
Skari's Avatar
Skari
Hi.
I think this is the right place to ask about Escape.
The thing is I recently bought a 2004 (so my registration card says) Escape XLS automatic(the registration also says limited).
My research showed me that only 2004 automatic Escapes had 6cyl engines, and the manual Escapes had 4cyl 2000cc.
But when I got it to oilchange They told me it was only a 4cyl engine.
Fine I said, but I checked the Vin number that was in my registration on Ford Trucks VIN Decoder and it said my car was a 2005 4cyl 2300cc. And my registration card again says he was on the road july 2004.
Can this make any sense?
Best regards.
Skari
Iceland...
Old Mar 7, 2012 | 11:20 PM
tcesni's Avatar
tcesni
Automakers can begin to sell cars meeting specifications for a model year well before the calendar year begins. Typically in the U.S., the new model year begins in Sept - Nov, for instance the 2005 models hit the showrooms in Sept - Nov 2004 but sometimes it can begin quite a bit earlier. It is likely that your Escape is a 2005 model but that the model introduction began a bit earlier than typical. Having the 2.3L engine is certainly an important designation. I can't explain the XLS vs Limited issue though.
Old Mar 8, 2012 | 03:04 AM
Skari's Avatar
Skari
Thank you for your good answer, this explains few things.
Old Mar 10, 2012 | 08:31 AM
martin_csr's Avatar
martin_csr
Not sure what you need to know now.
Try entering the vin at FordParts.com & click around to see if that's any help.
Using the site, the 2005 XLS 4-cly had either an automatic or manual transmission & there were 2 of each (4 total different transmissions).
Old Mar 10, 2012 | 02:15 PM
Archion's Avatar
Archion
Veteran: Marine Corps
If the 10th digit of the VIN is a 4, than it is a 2004, 5=2005
troy676
Jan 4, 2015 09:06 AM
lombardo96
Jun 16, 2006 06:44 PM
kkester
Car/truck Buying Advice
Nov 28, 2005 08:41 PM
jkmcgrath
Jul 6, 2005 09:50 AM
crowtf
May 19, 2004 08:50 AM
