Is it the Alternator?
Old Mar 7, 2012 | 05:03 PM
btdrygulch's Avatar
btdrygulch
98 Ranger 4.0..4WD ex CabXLT Automatic..started the engine yesterday and my charge light came on and stayed on. Checked the guage and it showed no charging and then slowly began to charge and the light went out. If I rev the engine above 2,000RPM's the charge needle starts to drop but if I keep RPM's below 2,000 charging is okay. Is this the sign of a failing alternator? The belt only has about 20,000 miles on it and tension seems oksy
Old Mar 7, 2012 | 05:42 PM
workaholic's Avatar
workaholic
Probably. After about 90K the bottom brush starts to burn a hole on the slip ring. And at first, before it completely burns thru, 9 out of 10 people notice different rpm's have an effect. There are some cheap fix it yourself alternatives on you tube and the net, or get to your fav. part store.
Old Mar 8, 2012 | 01:10 PM
97ranger xlt's Avatar
97ranger xlt
put a voltmeter across the battery and see what it's putting out.
when mine went, i got a used alternator at a junkyard for $25 and it has been working fine for 3 years...
Old Mar 8, 2012 | 02:26 PM
merlynr's Avatar
merlynr
Daughters' zx2 did that at 3k rpms As soon as it touched 3k, the voltmeter would drop to battery voltage. replaced alt as it was over 100k miles.
Old Mar 8, 2012 | 03:36 PM
workaholic's Avatar
workaholic
typical
alot of people say that. If you saw lots of em torn apart, like I have, it seems like they all got the same thing wrong with em.
bbsitum
1997 - 2003 F150
36
May 2, 2019 09:26 AM
myke
1997 - 2003 F150
Mar 16, 2005 06:49 PM
neufelda
Jun 28, 2003 09:37 AM
bobward737
Mar 26, 2003 08:43 AM
mchild
Electrical Systems/Wiring
Sep 29, 2002 01:29 AM
