Sponsored by: Real Truck
Remove Front Sway Bar?
Old Mar 7, 2012 | 04:54 PM
cbzdel's Avatar
cbzdel
Here is a question, not saying I am going to do it, just thinking what if...
In the past on my offroad rigs, I took off the sway bars and never though twice about them, with a huge lift it wasnt going to save much in the first place plus it killed articulation. And I never had a single issue, but then again I dont drive like a bat out of hell in a lifted rig haha!
I am now debating a 4-link lift kit for my truck, and I am sure the front sway would kill articulation once again.. I have never owned anything as large as this F250.. Hows a truck like this handle without a front swaybar?? I do not tow either.. There is also no rear swaybar on my truck, not sure it they came with one or not though..
Old Mar 7, 2012 | 04:57 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I took mine off to redo the bushings, and never put it back on.. I do have a good amount of body roll in turns, but as long as youre careful, youre not going to roll it. Its not really a problem, just more of a nuance to slow way down for some turns.
Old Mar 7, 2012 | 05:02 PM
abendx's Avatar
abendx
Too dangerous for a street rig... better idea would be to fab up some kind of quick disco.
Old Mar 7, 2012 | 05:05 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Youre in Oxnard? I'm in Ventura!
Old Mar 7, 2012 | 05:59 PM
abendx's Avatar
abendx
What's up neighbor.
Old Mar 7, 2012 | 06:08 PM
Shake-N-Bake's Avatar
Shake-N-Bake
My '99 only came with a sway bar up front, I later added one on the rear. Around 4 or 5 years ago my bushings were toast so I ordered a kit to change them out but of course they didn't fit (e99 vs late 99 thing..). So, I drove around for a few weeks without the front sway bar while I waited for the replacement parts. It was a little scary on turns but otherwise it drove fine. I was pretty happy to get it back on there though.
I think there are kits on the market for quick disconnecting the sway bar for off road use. You might consider looking into those and see if anything fits.
Old Mar 7, 2012 | 06:15 PM
Shake-N-Bake
Total here...sorry to the OP.
Trey, I didn't realize that you hadn't yet re-installed the bar yet. I saw your other thread about the end link upper bolts. On my truck there wasn't anything in that frame bracket, the bolt just went through from the inside-out. There was some clearance around the bolt but not excessive.
If you have the Energy Suspension kit, then you will need to install the bushings with the thicker edges at the top of the end links and the bushings with the stepped edges on the bottom. Then you will press in the hardened steel sleeves to bind them together until you re-install the end links. When you attempt to re-install the bolt through the upper end links, the shoulder on the bolt won't fit inside the steel sleeves. The fix is to install the bolt from the outside-in so the nut is on the end link side and the head of the bolt is outside the frame. Everything else is reverse order as removed.
Hope this helps.
Old Mar 7, 2012 | 06:17 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Hope this helps.
Thanks. Got that end link thing figured out! The end links I have already have bushings pressed in. I just have to get one of the brackets off and flip it but clearance is bad and its stuck! 2 bolts are all that is stopping me from putting it back on.
Random question. Are the end link bolts special? Or can I get them at a hardware store?
Old Mar 7, 2012 | 06:43 PM
Fordfanatic4life's Avatar
Fordfanatic4life
if the truck is lifted i wouldnt worry about the front sway bar.
the extra spring rate from the springs is usually more then enuf to help overcome what the stock swaybar helped with..
esp. if its a leaf sprung vehicle.
Old Mar 7, 2012 | 07:32 PM
Shake-N-Bake
The hardware is special in the sense that they are the washer head type and most likely harder than a standard grade fastener. They also are silver cadmium plated, which has some specific benefits when used in chassis parts. In a pinch you can surely pickup some grade 8 parts at your local hardware store and put it all back together. Some hardware stores will carry golden cad plated in grade 8 so you would want to get those if possible. Black Oxide would be a great second choice if cadmium plated isn't available. In your climate you will be fine. For those in 'less than dry' climates, I would recommend they order OEM fasteners so they can benefit from the cad plated stuff.
Old Mar 8, 2012 | 02:10 AM
Firekite's Avatar
Firekite
Please put the sway bar back on there. All it takes is one little unexpected swerve and you're just along for the ride. A guy I know is lucky to be alive after a minor swerve on the highway resulted in a flipped rig, lots of bruises, and a lesson learned. I crawl rocks in my TJ, so I finally switched over to a Currie Anti-Rock on it, and even with it on its loosest setting it's still so much better behaved both on-road and off than no swaybar at all and with no significant reduction in articulation. And if you're not crawling rocks with your Super Duty (!!) then you do NOT need more articulation than you're getting.
And whoever said that lifted springs make up for your swaybar: no. No, they don't, especially if they're quality springs. If anything you'd have to make up for it with wildly aggressive shock valving, and that would be murder to drive. Don't run without it. It's there for a reason.
Old Mar 8, 2012 | 06:24 AM
Smokeispower's Avatar
Smokeispower
If anything, a lifted truck needs a swaybar more than a stocker - higher center of gravity means more lean in the corners. And springs for lifted trucks are not stiffer, at least they shouldn't be, they just have a taller free height. So IMHO you need a front swaybar, but I'm sure some drive without, and the ones here that have admit that there is a big difference.
Old Mar 8, 2012 | 02:56 PM
saz2686's Avatar
saz2686
If looking for better offroad articulation leave the sway bar off and consider a castor kit. I know your thread is not intended to resolve steering wander issues but I think this is related to your desired outcome. Read post 21 .
https://www.ford-trucks.com/forums/1...l#post10642310
Old Mar 8, 2012 | 06:55 PM
mwsF250's Avatar
mwsF250
As long as you can prevent all the other idiots on the road from doing something stupid in front of you, you don't need it.
But if you ever need to make an emergency evasive maneuver, you will sorely (literally, as Firekite mentioned above) miss it.
Personally, I haven't figured out how to make the idiots go away...
If you do enough off roading to warrant it, make, modify, or buy a quick release sway bar disconnect for off road use, but for your own sake, keep it connected on road!
Old Mar 8, 2012 | 09:04 PM
acstator's Avatar
acstator
Trailering
I'm new to the 4WD large pickups, but I've been rockcrawling Jeeps since 1981. I've run with and without the front swaybar on the highway and the difference is incredible. It's much harder to control a rig without the sway bar. My '82 Scrambler has custom made disconnects and I refuse to drive on the pavement without connecting them. It's way to scary in the turns and, as mwsF250 so eloquently states, "you can't make the idiots go away"!
I agree with his statement that you need to have some disconnects and use them.
Dan
