Is My Injection Pump Missing A Part?
Old Mar 7, 2012 | 01:28 PM
Blitzcraig's Avatar
Blitzcraig
The injection pump I found in a salvage yard has a red plug on the left hand side of it. The one on my truck is identical except there is no plug. My truck is a 93 turbo and the other pump is off of a non turbo. Should I remove the plug? What does it do? I have no loose wires that would plug into it.
Old Mar 7, 2012 | 02:23 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Left side ... I'll assume you are using the industry standard view of this, As setting in the drivers seat! Thus this plug is on the drivers side of the IP ...
I suspect it's for an Automatic Transmission Truck.
Did that pump come off an Automatic Truck ??
If it did, then it's the VRV (I believe it's called, don't do Automatics) for the Automatic Trans ... Forget about it or remove it.
VRV = Vacuum Regulator Valve
Search for VRV on this site you'll get plenty of info and likely some pics.
-Enjoy
fh : )_~
Old Mar 7, 2012 | 04:16 PM
Blitzcraig's Avatar
Blitzcraig
Thank you Mr. Hagen. It was an automatic. I shall remove it post haste.
Old Mar 9, 2012 | 01:44 PM
Festus Hagen
Methanoholic
No prob.
-Enjoy
fh : )_~
timmyboy76
30
Jan 22, 2018 08:39 PM
bkohne1
May 30, 2010 11:06 AM
John with beastly 302
Sep 23, 2009 10:13 AM
kawa
Mar 30, 2009 02:10 PM
jeter
Jul 15, 2004 09:36 PM
