Beans chip
Old Mar 7, 2012 | 10:26 AM
j250hd's Avatar
j250hd
Beans chip
Just looked and their price dropped to 399! who here is running their tunes. What do you think about them? I read a thread awhile ago that someone went up to their place and tested a bunch of tuners on the dyno. But I think he's running dp or tw tunes even though he got better #'s with beans, just wondering why? I plan on stage 1's and bts valvebody this summer. I have intake and exhaust right now.
Old Mar 7, 2012 | 12:33 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
I dont know any about Beans chip, this is a bump for you.
BTW do you have gauges?
Old Mar 7, 2012 | 12:37 PM
j250hd's Avatar
j250hd
Scangauge will be bought at the same time. I drive like a grandpa cause I don't want to break anything and tow 2 times a year which isn't heavy so not too worried about egts and tranny temp.
Old Mar 7, 2012 | 10:41 PM
oldbird1965's Avatar
oldbird1965
I have beans tunes. Jonathan is great to work with and after a couple of reburns he about has me tuned in where I want. I also have a TW chip and it is real good also but needs the shift points raised up a bit.
Old Mar 8, 2012 | 01:33 PM
1dieselman's Avatar
1dieselman
Glenn, I noticed a while back that you use the cure which appears to be unavailable. Have either of the chips that you use gotten to where they can separate the converter lockup from the shift. I hate when the converter locks at the same time as the shift and the rpm's drop low.
Old Mar 8, 2012 | 02:03 PM
superduty4x4's Avatar
superduty4x4
That was Neal, and he did it to prove a point. If you found the thread that talks about his dyno runs, keep reading back and you'll get the full story.
Old Mar 8, 2012 | 08:29 PM
Talyn's Avatar
Talyn
He still needs to update that thread also. =)
Johnathon has good reviews on his tunes.
Cale does great tunes as well.
I'll be switching to Jody's tunes.
Old Mar 8, 2012 | 10:40 PM
ccarrier's Avatar
ccarrier
when neal and i went to beans, we were treated top notch. they dropped everything to help neal with his tunes. beans tunes made good power.
with that being said , ill stick to my dp tunes. they are more driver friendly. thats just me though.
Old Mar 8, 2012 | 11:22 PM
oldbird1965
Yes, I had a lot of problems with that. Tony's chip at first was locking the TC BEFORE it shifted into 3rd making 3rd shift really hard. He then raised up the TC lock so it was after the 3rd gear shift. This helped alot with the dropping of the rpm's after it locked because it was at a higher rpm. I still would like more of a separation between it shifting into 3rd and when the TC locks but its so hard to get without live tuning. I would love to get on Beans dyno or anybodies to get it dialed in perfect, if there is such a thing!
Old Mar 9, 2012 | 08:50 AM
1dieselman's Avatar
1dieselman
Thanks Glenn, good info.
JMalmy21..00/7.3
Jun 25, 2012 07:14 PM
dthompson
20
Jan 29, 2010 11:40 AM
cattlerancher
26
Jul 7, 2009 10:33 AM
turboalways
Mar 3, 2004 03:39 AM
