Stalls when warm!!!?
Old Mar 6, 2012 | 04:02 PM
Alex24's Avatar
Alex24
I got a 03 f250 6.0 with 180,000 miles on it. Has egr delete kit, new injector, icp and connector . I have no codes . I've noticed once it gets warm it will stall when it's trying to shift with rpm's in between 1 and 2000. I cant get over 40 mph when it totally warm. If it still cold I can go speed limit but once it's warm it start bucking and jerking and eventually stall. After it stalls it take 3 times of turning key on and cranking to turning key on and cranking till it start.. Then it run like crap ..anyone got any suggestions.. It's much needed and greatly appreciated
Old Mar 6, 2012 | 04:48 PM
BLADE35's Avatar
BLADE35
Kinda sounds like its starved for HPO
Got any gauges?????
Need to monitor ICP and IPR%
OEM Oil Filter and OEM Cap???
Old Mar 6, 2012 | 05:21 PM
Alex24's Avatar
Alex24
Gauges but only came with boost ext temp and trans temp from previous owner.. I was think sct fitting would that be likely or no.. I'm waiting fr tax return money to come to get a scan gauge II
Old Mar 6, 2012 | 05:25 PM
BLADE35's Avatar
BLADE35
What year truck is it???
STC fitting goes they usually dont run till repaired
Standpipes or dummeyplugs probably more Likely or Oil Filter/oilfiltercap issues
OEM Oil Cap and Filter??????
Old Mar 6, 2012 | 05:30 PM
npccpartsman's Avatar
npccpartsman
No STC fitting on an 03. Pull and check the IPR valve for trash and diagnose for an HPO leak. Also check the FICM voltage.
Old Mar 6, 2012 | 05:46 PM
Alex24's Avatar
Alex24
It's a 03 ..ficm voltage is 48 all around..I'm unsure of the filter an cap..I will change oil this weekend or atleast pull filter and cap out to check
Old Mar 6, 2012 | 07:24 PM
BLADE35's Avatar
BLADE35
I missed the 03 in your first post my bad
Hopen just the Cap and or filter combo is wrong 03s dont have to many HPO problems
read this threead it shows the right and wrong caps
WRONG OIL FILTER CAP CAUSING UNFILTERED OIL TO TAKE OUT THE IPR
https://www.ford-trucks.com/forums/1...lew-again.html
Old Mar 6, 2012 | 07:33 PM
2006powerstroke90's Avatar
2006powerstroke90
Since its an 03, no STC fitting as mentioned....they are on the 05's+ HPOP's
I would check FIRST oil filter and cap, the remove IPR and check screen for damaged/clogged screen as mentioned.
If FICM is good, we can rule that out.
Any recent work done?
Old Mar 7, 2012 | 03:25 AM
Alex24's Avatar
Alex24
Anyone by chance know the oem ford oil cap part number
Old Mar 7, 2012 | 03:34 AM
Alex24's Avatar
Alex24
Also when it does start acting up I hear a noise in engine compartment it's almost like a hiss/wind. Its hard to explain exactly what it sounds like. But it only happens and makes this noise when it's warm and its in the upper rpm around 1300 and 2000
Old Mar 7, 2012 | 03:37 AM
Alex24's Avatar
Alex24
And once it shifts to next gear the sound goes away till next gear. When I'm running against a wind it is horrible and I have a hard time going 40. The sound also somewhat sounds like something spinning super fast that is metal . Any clue?
Old Mar 7, 2012 | 05:17 AM
npccpartsman
Do you have a boost gauge? You might want to check your turbo boots, y-pipe, and intercooler for splits.
Old Mar 13, 2012 | 06:20 PM
Alex24's Avatar
Alex24
Alright everyone here's the latest scoop. Took it to dealership and they said it needed a new icp an ipr valve and ipr valve connector.. Since I just put new icp in they don't charge me for the one they put it. I picked it up today before I even made it out of town it started doing it again ..any thought on this. I'm calling dealership tomorrow and gonna have my words with them even tho it pry won't get me very far. All thought are welcpmed thank tou
Old Mar 13, 2012 | 11:50 PM
BLADE35's Avatar
BLADE35
Do you have an OEM Oil Cap & Oem Filter too
Did you get a ScangaugeII yet??
Old Mar 14, 2012 | 03:41 AM
Alex24's Avatar
Alex24
Does anyone have the part number that way I can check it for the oil cap that is. I have not yet got a scangauge II yet I will pry order it tOsay or tomorrow
