what is a mini starter
Old Mar 5, 2012 | 09:53 PM
wildcard221's Avatar
wildcard221
what is a transmission mini starter....and what does it do exactly?
Old Mar 5, 2012 | 10:00 PM
fmc400's Avatar
fmc400
MSEE
A mini-starter (PMGR) typically users a planetary gear set to deliver higher torque to the drive gear. They are typically smaller and weigh less. It does the same job as a conventional positive-engagement style starter, just more efficiently.
PMGR starters have the solenoid mounted on the starter itself, but when retrofitting a PMGR starter to these era trucks, the fender-mount solenoid is still required; this time it acts as a relay to the PMGR starter solenoid coil (a relay to engage another relay).
Here's a decent writeup: High Torque Mini Starter Installation. PMGR Starter. - FordMuscle
Old Mar 5, 2012 | 10:04 PM
wildcard221
come on bro you used waaaay to big of me....could you dumb it down a little more that would be a big help thanks... also is it worth buying and installing
Old Mar 5, 2012 | 10:05 PM
HIO Silver's Avatar
HIO Silver
A mini-starter is an engine starter of reduced size compared to OEM. Some guys get'em for header or chassis clearance.
Starters operate by a solenoid engaging a bendix drive (like a corkscrew) with a gear at its end and projects from resting position during "start". The starter gear engages the flywheel (manual trans) or ring gear (welded to the flexplate which in turn is bolted to the torque converter) to rotate the engine components (crank, rods, pistons) with sufficient velocity to initiate ignition.
When you release the key from the "start" position, the lil gear retracts back into the starter body. ..... and that explains why a starter will grind when it is initiated with the engine already running.
Dig?
Old Mar 5, 2012 | 10:08 PM
85e150's Avatar
85e150
Real short answer--unless you need a compact, high performance starter for a high performance, high compression engine, just stick with a quality rebuild.
http://www.jegs.com/p/JEGS/JEGS-Mini...51068/10002/-1
Old Mar 5, 2012 | 10:14 PM
fmc400's Avatar
fmc400
MSEE
Okay...I'll try again:
Less size.
Less weight.
More power.
More money.
Takes some work to wire up.
Does that work?
I run a mini-starter, ONLY because I needed it to clear my headers. Unless you have some specific need for it (some of which are mentioned in the above post), I don't think it's worth spending money on.
Old Mar 5, 2012 | 10:24 PM
wildcard221
thanks that makes alot more sense...and since you know what your talking about (HIO silver) and use small words for simple folks like me...any idea how to do fiberglass stuff i want to make a fiberglass cluter gauge to put my tach and stuff on and maybe a new box for my subs.
Old Mar 5, 2012 | 10:25 PM
wildcard221
and yes thanks fmc400 i should of told you im not too good with big words...LOL
Old Mar 5, 2012 | 10:52 PM
HIO Silver's Avatar
HIO Silver
Yeah. In a nutshell, ya design and build an enclosure out of MDF, stretch fiberglass fleece over and staple it, apply resin, apply a layer of fiber mat and resin that too. Then apply plastic body filler, finish, paint, and install.
Better yet, read through the following DIY threads:
DIY: custom fiberglass subwoofer enclosure guide - RX8Club.com
DIY: Fiberglass Speaker Enclosures - RX8Club.com
Old Mar 6, 2012 | 01:16 AM
wildcard221
sweet is there anything you cant do or dont know... no i can redo my sub box and mount my tach where i can actually see it
WaveyDavey1980
Apr 18, 2019 09:31 PM
MikeTexas3878
4 Cylinder Engines
Aug 18, 2017 09:05 AM
leforrest
1997 - 2003 F150
Jan 24, 2013 07:34 PM
dalkris95
Sep 17, 2012 02:57 AM
Kendrick
Apr 9, 2011 08:58 PM
