tire psi
Old Mar 25, 2012 | 08:36 AM
  #31
Supercab's Avatar
Supercab
MY LATE '99 F350 DUALLY (2wd) says 60psi both front and rear on the door sticker-I understand that the EARLY '99 DUALLYS are different-45psi?? and I'm not sure why....
IF I run 60psi (to say nothing about the max 80psi) in my rears I will be lucky to have an inch of tread contacting the ground in the center of both tires-(I run empty about 90% of the time.
I am having an odd wear problem with my front tires which I keep pretty much at 80psi-I have tried the 60psi that the factory recommends then 70 then 80 with no change-I have to run no more than 45 psi in the rears to have full pavement contact-I am running Cooper Discoverers 23585R16E Highway tread tires which are pretty similiar to the original Generals that came from the factory on my truck.
The PO of my truck put some ULTRA-EXPENSIVE Michelins in the same size on the front and the truck chewed them up-the BIG TRUCK shop here in town has alligned it and says everything is good but it is still weraing my (cheaper) Coopers out weird.
Old Mar 25, 2012 | 06:41 PM
  #32
Tugly's Avatar
Tugly
I feel your pain. I'm trying different pressures with an eye on comfort, a sharp eye on wear, and a sharper eye on fuel economy. Yes - I am a freak.
Anyway, I get cupping on the outside of the wheels and I have paper here that says I'm in alignment. I tried shocks as a last measure and rotated the tires. I now have 4 cupped tires.
I've heard countless tales of members with tread wear. Could they all be cupping edges on the outside like mine? Is it a different type of wear for others? Could it be the nature of turning corners that scrapes the tire edges?
Supercab - your tires are the recommended size. Do you like how they look on your truck? How is the steering stability?
Old Mar 25, 2012 | 09:07 PM
  #33
1WildPig's Avatar
1WildPig
Well, I've eased it on down again and am now at 56 front and 46 rear (at 60*F) ... and I still don't think the rears are running "flat" - but what a smoother ride! I'm gonna keep my eyes on those fronts for edge wear and watch my fuel mileage...
To Supercab and Tugly ... I thought cupping was a sign of bad shocks and maybe too much pressure - but as Tugly has replaced his, the mystery still persists ... hmmm, are the fronts rotated?
Old Mar 25, 2012 | 09:35 PM
  #34
F250_'s Avatar
F250_
My experience with cupping, and this is on the original Michelin LTX's, Bridgestone Revos, and my currently running Michelin AT2's is as follows... if you wait too long to rotate, you'll get cupping on the outer edges. I've seen it on every make I've run, and I admit to having a bad habit pf waiting too long to rotate.
Old Mar 25, 2012 | 10:57 PM
  #35
timmyboy76's Avatar
timmyboy76
In regards to rotating, i was told, (many many years ago, lol) to rotate back to front, and keep the tires on the same side. Reason being, is the wear pattern to the metal webbing. If tire was rotated to opposite side, it would help in the metal protruding thru tires? That statement hold water?
Old Mar 26, 2012 | 12:49 AM
  #36
1WildPig's Avatar
1WildPig
Yep, I grew up as you did timmyboy76, when radials came on the scene they were to be rotated only on the same side....but today, that no longer applies unless the tires are "directional" and can only be run in one direction - yep, I was behind the times too! ... which is why I asked if the fronts were rotated, I didn't know if they were directional as I thought these were on a dually ???
Old Mar 26, 2012 | 05:34 AM
  #37
Tugly's Avatar
Tugly
Les Schwab rotated the tires front to back. I did wait waaay too long to rotate, but the newly-rotated front tires are showing that cupping pattern pretty quick - it's only been about 2500-3000 miles. It's not bad, but I see it.
I think this one topic warrants a dedicated thread. I'll see if I can open one without starting a conflict over cupping.
SoCal69
May 12, 2019 12:03 PM
ysgi
Dec 28, 2016 05:24 PM
MC5C
Apr 24, 2013 06:39 PM
45 ACP
May 3, 2010 10:23 AM
ecrailings
15
Oct 18, 2006 03:01 PM
