Sponsored by: Real Truck
Cab light problems
Old Mar 5, 2012 | 04:58 PM
steensm's Avatar
steensm
Cab light problems
I have a 2010 250 and had the cab clearance lights installed through the dealer. I have been havinf some problems with a couple of the lights going out sometimes then coming back on. There is a short somewhere and i have no idea where to find it. Any suggestions?
Old Mar 5, 2012 | 08:33 PM
rkmfordman's Avatar
rkmfordman
start with checking all the bulbs for corrosion at the contact points use di-eletric grease on all contact points if it is a wiring issue u will have to remove headliner its fairly simple if u have factory lights they will plug in to bottom of light check plugs for corrosion use a little di-eletric grease on plugs too the wiring harness runs down the passenger side windshield post and plugs in behind the passenger kick panel shud be easy to trace a bad wire with a tester
Jagoeb
Jun 6, 2018 11:47 PM
coley909
Aug 30, 2017 08:49 PM
iwals
Oct 9, 2010 09:08 PM
wbtguy
Electrical Systems/Wiring
Nov 4, 2004 07:49 PM
Coneynew
Feb 25, 2003 06:17 PM
