Wiring Question
Old Mar 5, 2012 | 02:54 PM
dennisb56's Avatar
dennisb56
Wiring Question
Hello, I am converting my 52 from 6V to 12V. I've looked at a lot of the postings both old and new. I have all of Dan/Julies stuff as well. I think I have it right so far but want to be sure. I've removed the generator, voltage regulator, old keyswitch, old solenoid, and push button. I added a new 10Si 3 wire Alt, a new ignition switch and solenoid.Wish I knew how to draw a picture but will just try to convey my wiring point to point.
From Battery side of solenoid to BAT on keyswitch
From IGN of keyswitch to I post on Solenoid
From I post of Solenoid to + post of coil
From START on Keyswitch to S post of solenoid
If anyone can decipher this and tell me if this sounds correct I would appreciate it.
Thanks
Old Mar 5, 2012 | 04:28 PM
OldStyle's Avatar
OldStyle
Rusty Roller
Thanks
From Battery side of solenoid to BAT on keyswitch correct
From IGN of keyswitch to a Ballast Resistor then to the POS side of the coil
From I post of Solenoid to + post of coil correct
From START on Keyswitch to S post of solenoid correct
When you crank the starter the "I" post supplies 12v to the coil for starting. When released then the coil gets it's "reduced" power thru the ballast resistor making the points last longer.
Please feel free to correct me if I am mistaken.
Old Mar 5, 2012 | 05:18 PM
old_dan's Avatar
old_dan
I think Old-Style is correct!
Here's a link to a thread with an illustration....the solenoid in the picture isn't labeled with the I & S, but here it is: https://www.ford-trucks.com/forums/1...2v-switch.html
Dan
Old Mar 5, 2012 | 05:47 PM
dennisb56's Avatar
dennisb56
thanks OldStyle and Dan, I thought I was close but just wanted to be sure. I did not want to let the smoke out!
Old Mar 6, 2012 | 04:21 PM
dennisb56's Avatar
dennisb56
Finished my 12 volt negative ground GM Alternator today and it lives!!! It started so quick like a new truck. Now on to the entire new Speedway wiring harness! I just ran wires point to point for this to test things.
Thanks for the support on this question.
Old Mar 6, 2012 | 10:47 PM
mbarrad's Avatar
mbarrad
Congratz! I just finished up my 12 volt conversion on my 1951 last weekend. Certainly is a confidence builder for sure.
RICHMC54
Oct 30, 2011 02:24 PM
first rebuild
Feb 20, 2011 02:49 PM
quisp-n-quake
Electrical Systems/Wiring
Mar 29, 2010 03:34 AM
Stephen_E
May 9, 2004 01:50 PM
mk
Mar 14, 2002 10:21 PM
