I bought some for my 06 F150. Sadly, I can't find the invoice to tell you what I got, but I don't know if the 09+ use the same type of LEDs or not anyway. One thing I can tell you is make sure that you get either cool or natural white colored LEDs. Don't get warm white as it is basically the same dull yellow color you would have now. Also, it probably doesn't hurt to get the strongest light that will fit, but don't waste money on ones that have a 360 degree beams as you don't have a need for them. Stick with the 120 or 180 degree ones. It took me a lot of research until I finally found the right bulbs, but hopefully you won't have to do the same. I did order from that site though by the way so they should have everything you need.
front dome lights are 194, rear dome light and both reading lights are 578 (small tubular lights), reverse lights are 921/912 and those can also be used for the cargo light/3rd brake light. license plate is 194. replaced all mine using blue leds for dome lights and white leds for the reading lights reverse light and cargo lamps.
