Heat shield and manifold gaskets sequence
Old Mar 4, 2012 | 12:31 PM
asidpara's Avatar
asidpara
I have 67 F-100. In the kit I got two manifold gaskets and I also have heat shields. Can some one explain their sequence. I waws thinking to sandwich heat shild between ntwo manifold gaskets. Please let someonw if this noy right. Also both manifold gaskets are of different shape and I am not sure wich one goes where. My shopm manual does not go into this details. If there is a picture, that would clear up everything. I will appreciate some help. At this time I am stuck!!
Old Mar 4, 2012 | 12:41 PM
Freightrain's Avatar
Freightrain
What motor?
FE is all the same.
302 has early and late style intake gaskets.
Heat shield? Not sure.
Old Mar 4, 2012 | 12:54 PM
asidpara's Avatar
asidpara
It is 5.8L. 352 CID,Manual
Old Mar 4, 2012 | 01:04 PM
Freightrain
Been many years since I've seen a typical rebuild gasket set I'm not sure what they gave you.
You only use one gasket per side. Not sure what this heat shield thing is? Block off for heat crossover?(just a small square). Only sheetmetal under the intake on an FE is the heat shield that clips under the head gasket edges and goes down into valley.
There are a few different port sizes for FE intakes, so I would use the gasket that best fits your heads.
Old Mar 4, 2012 | 04:39 PM
HIO Silver's Avatar
HIO Silver
FYI... here is the heatshield on my 70 with a 360FE. No gaskets anywhere... just the heatshield and it doesn't leak.
Old Mar 5, 2012 | 07:00 PM
Freightrain
Ahhh, EXHAUST MANIFOLD. That explains a lot.
You aren't suppose to use gaskets on exhaust manifolds, as they only blow out in short order. They are a band aid fix for poor sealing surfaces, and short lived.
fromme87
Oct 24, 2015 05:21 PM
ford66
Aug 17, 2009 08:09 PM
buckrogers
Dec 5, 2008 11:36 AM
phantmlord
Exhaust Systems
May 27, 2007 01:33 PM
gregg_a_g
Feb 26, 2007 05:45 PM
