This engine is a 2bbl. If I understand correctly, the 289 2bbl has dished pistons and the 289 4bbl has flat-top pistons. Will there be a clearance problem if dished pistons in this motor are replaced with the 4bbl flat-top pistons?
Ask in the specific small block forum
289s were never installed in f series trucks, so unless someone has specifically installed one it will be tough to pull an answer from here
1965/68 2V & 1965 4V regular fuel 289 pistons are the same.
1965/68 premium fuel 289 4V pistons are different.
