Flat top pistons
Old Jun 6, 2006 | 11:41 PM
78ford_shortbox's Avatar
78ford_shortbox
Flat top pistons
I am rebuilding a 400m and was wondering what the benefits are of putting flat top pistons in and if they are worth the extra money.
Old Jun 7, 2006 | 01:23 AM
Torque1st's Avatar
Torque1st
Posting Legend
A 400 (no M) really wakes up when the compression is increased. It was a real good engine when introduced in 1971 and everybody wanted one. Unfortunately they ruined it the next year.
High Performance Options for the 351M/400 Engine by Dave Resch
Old Jun 7, 2006 | 11:27 AM
78ford_shortbox
that's kool but it doesn't answer my question.
Old Jun 7, 2006 | 05:19 PM
packlet's Avatar
packlet
yes it does.
stock pistons have a big dish in them. flat-tops don't.
so with everything else the same, you get higher compression.
Old Jun 7, 2006 | 11:29 PM
78ford_shortbox
about how much are they?
Old Jun 8, 2006 | 12:46 AM
roger dowty's Avatar
roger dowty
TMI (sponser) sells the Badger for 170 or so. Not sure what he has in stock. SOmetimes you can find them for a bit less but they are not always abundant and tim has a lot of knowledge to go along with his product. Search this forum and you will find a plethora of info...
There a 3 ways to legitimately bump compression which is what the 400 needs to make it a legitimate contender with the best of motors- which it is. You can go with stock pistons and heads off australian 351b motors- cost 4-$500 or more to your door
but them you can buy special made kb pistons from tmi that provide incredible quench and 9.5:1 cr that will run on 87pump- with performer intake and carb and you will get an easy 440 ft lbs and 340hp with a rv type build.
You can also get the badger pistons or kb flattop pistons for a cleveland and have them bushed- similar result.
Next is to deck the block and heads etc....more expensive and limits use imo.
Old Jun 10, 2006 | 07:30 PM
factory594x4's Avatar
factory594x4
How high can you bump compression on an 78' egr 400, and keep it smog legal?
Old Jun 10, 2006 | 08:10 PM
78ford_shortbox
dunno man i live in canada so i'm good to go.
Old Jun 10, 2006 | 09:12 PM
Torque1st's Avatar
Torque1st
Posting Legend
Keeping it smog legal would be about 8.0:1, otherwise the NOx increases etc. That is why it was reduced in the first place. You would also have to have all of your emissions equipment operational.
Old Jun 10, 2006 | 09:52 PM
grclark351's Avatar
grclark351
gotta wonder if the current fuel blend is enough to help a 9:1 engine pass? it's been a long time and a lot of changes in the fuel since they "smogged" the 400 to death. i suspect the doctors lost that patient unnecessarily. new vehicles are coming out at 10:1 and higher under much more stringent standards, granted they are computer controlled but there should be a happy medium for the tune-up that'll get you through the lane
Old Jun 11, 2006 | 02:03 AM
packlet's Avatar
packlet
fwiw: i'm running ~8.7:1 static compression and have had no problems passing smog in CA. then again, my '82 E350 is considerd 'heavy duty' and got a break emissions-wise. latest smog cert in my gallery.
Old Oct 19, 2021 | 12:41 PM
DaveMcLain's Avatar
DaveMcLain
Those pistons look like the Autotech/Racetech pistons. They are about the most reasonably priced custom pistons available right now. The set that I got from them a couple of months ago took about 8 weeks to arrive. It'll probably take a heck of a dish to keep your compression below about 8.5:1. I'd have to figure it out but I bet that you'll need about 25cc or so.
Old Nov 7, 2025 | 01:07 PM
beartracks's Avatar
beartracks
Back to nomad, ignition curve can also be manipilated to deal with compression.
Old Nov 7, 2025 | 10:38 PM
SDDL-UP's Avatar
SDDL-UP
I want to say a flat top piston in a 400 is something like 12:1 compression. I.E. not street friendly. This is why TMeyer has been so successful with his line of pistons.
AutoTech / RaceTech will make you a custom forged dished piston in whatever compression you like for a reasonable price.
Old Nov 8, 2025 | 07:44 AM
manicmechanic007's Avatar
manicmechanic007
I had a 71 LTD with a 400 in it
It needed a bit more compression too
