MYSTERY WIRE
Old Mar 4, 2012 | 12:09 AM
Rob_in_Alberta's Avatar
Rob_in_Alberta
MYSTERY WIRE
Just had a look under the hood today and found a black wire with purple trace sticking out (broken) from the passenger side under the wiring cowl near the heater. All electrical in the truck seems to be functioning. Would like to id this thing before ripping into the wiring harness. Thoughts?
Old Mar 4, 2012 | 08:58 AM
CanadaGuy's Avatar
CanadaGuy
Do you have a picture?
Old Mar 4, 2012 | 09:18 AM
Rob_in_Alberta
That would probably make it easier!
Old Mar 4, 2012 | 01:57 PM
Rob_in_Alberta
The only AM electrical equipment under the hood is a NuStart remote starter/alarm combo. I checked the functions on this and they both worked. I cannot find a black/violet wire in any of the Ford wiring diagrams I have look at.
Old Mar 4, 2012 | 02:21 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
It looks to me like speaker wire......maybe PO just cut his custom stuff out.
Old Mar 4, 2012 | 02:43 PM
Rob_in_Alberta
Man, I hope so, that would be a relief.
Old Mar 4, 2012 | 03:38 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
If you have been driving it and haven't encountered any problems....don't try to fix something that ain't broke!! Sound ok?
Old Mar 4, 2012 | 03:58 PM
Rob_in_Alberta
You bet. I intend to trace it back once the weather is better. Thanks,
Old Mar 4, 2012 | 04:32 PM
CanadaGuy's Avatar
CanadaGuy
I'll look at one at one tomorrow at work, but if everything works okay, I might not worry about it. Does it look like part of the factory harness?
Old Mar 4, 2012 | 04:40 PM
Rob_in_Alberta
Yes it looks like part of the harness. It seems to be embedded into the black plastic cowl under the heater vents and above the turbo. There is a major group of wires running under there? I have been hesitant to rip it apart with the cold weather (being in Kingston). My luck I will break the plastic. Thanks for taking a look!
Old Mar 4, 2012 | 05:34 PM
2006powerstroke90's Avatar
2006powerstroke90
Did you test it for power?
Old Mar 4, 2012 | 05:50 PM
69cj's Avatar
69cj
I would cap off the end and put a note in the owners manual for future reference if any gremlins should pop up. If you're having no problems, don't go cutting into a harness for no apparent reason.
Old Mar 4, 2012 | 11:43 PM
John Irwin's Avatar
John Irwin
Kingston Alberta? Never heard of it. Kingston Ontario I have heard of, but then your name should be Rob_in_Ontario.
I also wouldn't worry about it.
Old Mar 5, 2012 | 06:10 AM
Rob_in_Alberta
Posted here last year from Edmonton.
6point0
Jul 22, 2019 10:31 PM
smashclash
16
Jun 14, 2010 12:26 PM
FLJ
Electrical Systems/Wiring
Jun 13, 2008 07:50 PM
skoalboy87
Feb 2, 2008 07:28 PM
