Identify this hood wire
Old Jun 6, 2010 | 10:06 AM
smashclash's Avatar
smashclash
So there's a wire that goes across the bottom of my hood. It's green with a yellow stripe. There is a blue plastic fitting on one end and the other drops down and connects to the main wiring harness near the brake booster. Well, I wanted to know what it was so i touched it yesterday and it literally broke off from the wire right inside the plastic housing. the connection inside the fitting that accepts (whatever goes in there) is super oxidized and unusable anyway but maybe next time i go junkyarding i can pick something up. Seems like an odd housing to hold a light. Any guesses what it is?
Here's a pic. You can see it running along the bottom of the hood. I put the blue connector on the plastic casing on the motor for reference.
Old Jun 6, 2010 | 10:18 AM
okiepc1's Avatar
okiepc1
My 85 F150 has that wire & it goes to a lamp that is extendable, you can pull it out and move the light to where you need it.
okiepc1
Old Jun 6, 2010 | 10:25 AM
smashclash's Avatar
smashclash
OK. so even if I got a new wire or plastic connection I'd still need to find this lamp extension as well? seem like I should just tape it off for now and if I ever come across something then go for it.
Old Jun 6, 2010 | 10:48 AM
okiepc1's Avatar
okiepc1
they were quite popular you should be able to find one at the junk yard. Mine still actually works & is rather handy.
okiepc1
Old Jun 6, 2010 | 12:11 PM
Fordzilla80's Avatar
Fordzilla80
Not Necessarily Okie.The underhood lights came on trucks with the Light Group option,or underhood toolbox.Alot of these lights still work,others don't.These are popular options,and when they appear in a junkyard,people grab them up.They are hard to find unless you are lucky to stumble across a truck that has just been released into the yard and still has the light.
Old Jun 6, 2010 | 12:13 PM
smashclash's Avatar
smashclash
what year models were these lights in? 80-86 only?
Old Jun 6, 2010 | 12:18 PM
Fordzilla80
Yes.I think the newer trucks have underhood lights,but I don't think they are the retractable kind like ours.These lights came on F-Series and Broncos.I heard somewhere they're often found on Broncos.
Old Jun 6, 2010 | 12:40 PM
Rogue_Wulff's Avatar
Rogue_Wulff
I've had one of those retractable light units in my truck toolbox for years. I guess I oughta get around to installing sometime.....
I like the fact that the cord is long enough to reach the rear wheel area, and the light has a magnetic base. Sure would be handy, if a tire ever needs changed in the dark.....
Not sure if the long wire is still in the box or not. Originally, I had grabbed both.
Old Jun 6, 2010 | 01:47 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Here is a picture of the underhood lamp for refference.
Found on 1980-1986 F-series and Bronco with either the Courtesy Lamp Group, or the Underhood Toolbox. More comon on Broncos because they were better optioned as a rule etc...
Old Jun 6, 2010 | 02:46 PM
smashclash's Avatar
smashclash
thanks explorer. i have a feeling finding one of these is going to be very difficult but i'll keep my eye out if i ever come across one.
thanks.
Old Jun 14, 2010 | 07:50 AM
smashclash's Avatar
smashclash
Could someone please do me a favor? I'm going to HD after work tonight and I forgot to get the diameter of the A/C line that has that foam wrap around it. You can see it in the above picture. It's the line right under the hood on the firewall that has the cracked rubber look all around it. I suspect it's 3/4" but would REALLY appreciate if someone could confirm. Thanks.
Old Jun 14, 2010 | 08:47 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by 81-F-150-Explorer
Here is a picture of the underhood lamp for reference.
More common on Broncos because they were better optioned as a rule etc...
EOTZ15702A .. Under Hood Lamp-Utility Lamp with 20" retractable cord / Obsolete
Fits: 1980/89 F100/350, F(Super Duty) & Bronco / No Ford Dealer or obsolete parts vendor has any.
Old Jun 14, 2010 | 09:18 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
And if you're ever in a salvage yard and you see one of them or the under hood toolbox, GRAB them, Especially if they are in good shape.
They are valued items.
-Enjoy
fh : )_~
Old Jun 14, 2010 | 09:57 AM
smashclash's Avatar
smashclash
Hmmm, I probably should have created a new thread instead of bumping this one since the only relevant question relates to the picture but here goes again:
Old Jun 14, 2010 | 10:14 AM
Festus Hagen
Methanoholic
If you're looking to put insulation over it, the OD is 1.125 (1-1/8").
-Enjoy
fh : )_~
