Need advice on wheels - size, offset etc.
Rev Guillotine 20x9 (link to picture below)
GUILLOTINE-#845
Here is what I need advice on:
1. Offset - deciding between 0 and +20. I figure the +20 will be close to stock and the 0 will put the wheel out a little less than an inch. Which do you think would look better for a 20x9 wheel?
2. Tires - stock tires are 32". I am thinking about either 33 or 34" tires.
3. Lift - if the truck looks good, I will keep it close to stock height. If I need a lift, my plan is a v/b mod spring swap. The truck I am purchasing has 98,000 miles on it and may likely be in need of new springs and shocks anyway.
Thanks in advance for the input and feedback!
