Anyone swap in a dana 60?
Just curious... I have been thinking if my 50 ever needed a serious repair I'd just source a 60 from the junkyard. I'm guessing it would bolt right in if I got one from a SRW truck, and I believe the DRW ones are largely the same only with spacers, at least if they are like the earlier ones. I don't know if the calipers and etc are the same, as most junkyards pull the calipers.
the superduty 60's don't seem to be as valuable as the old kingpin or even the 80's ball joint ones. I've seen them at junkyards for under $200 and seen them around here and there in the $300-$500 range.
And obviously the 60 is stronger and has more aftermarket upgrades.
I don't even know what algers is. I'm starting to see early super duties in the pick a pull yards, and if my calipers and rotors will fit (and I think they will), then I can probably pick up the entire axle hub to hub for under $200. Its like $100 for an axle or something but then they charge you extra for the shafts, hubs, spindles, etc... depends on who is working.
I think you need to spend a minute or two on google. They are a lot weaker than the 60, there are a million failures, and they have a lot more different parts than just the axle shafts, some of which was hinted at in my original post, had you read it, along with my reasons for considering an upgrade.
A quickie from Wiki,
Dana 50 Specs.
Ring gear measures 9.0".
30 Spline Axle shafts.
Gear Ratios: 3.55:1 - 5.38:1
No carrier breaks
Pinion shaft diameter: 1.375"
Pinion shaft splines: 26
Axle shaft diameter: 1.21"
Axle spline diameter: 1.31"
Dana 60 Specs.
Ring gear measures 9-3/4".
3.125" diameter axle tube.
Weighs in near 500 lbs. More or less depending on width and brake configurations.
OEM Inner axle shaft spline counts are 16, 23, 30, 32, 33 and 35.
40 Spline inner axle shafts and carriers are made for after market, high performance Dana 60 axles.
Pinion shaft diameter: 1.625"
Pinion shaft splines: 10 and 29
Gear ratios: 3.31:1 - 7.17:1
Carrier break: 3.31:1 - 4.10:1 and 4.56:1 - 7.17:1
Axle Shaft diameter
1.41” Front (32 Spline)
1.46” Rear (32 Spline)
1.50” Front (35 Spline)
1.50” Rear (35 Spline)
1480 Universal Joint (Front axle)
Brakes measure 13.66" for 2011 F-250 & F-350 trucks.
Brakes measure 14.53" for 2011 F-450 trucks (13,050 GVW).
Dana 50 Specs.
No carrier breaks
Dana 60 Specs.
Axle Shaft diameter
You... don't know.... what youre talking.... about...
seriously dude stop whoring up this thread, if you have something useful to post by all means go ahead, but if youre just gonna make up facts, tell me I don't need to do what we are talking about doing, and generally being a pest, then go get your post count up elsewhere.
Exoptable has made this swap, let's get his 2c. IMO the D50 is plenty stout for what I do, but if ya wanna upgrade, go for it - don't forget the pics!
https://www.ford-trucks.com/forums/9...excursion.html
The D60 swap is strait forward when going from same drive line ( transmission, ESOF and SRW) F250 to Excursion. You should also use the shorter drive shaft that goes with the D60 axle on the donor pickup. There are 2 types of wheel studs (coarse and fine pitch) that should be matched with what you already have.
