really need help
Old Mar 3, 2012 | 02:50 PM
198769ford's Avatar
198769ford
really need help
so sometimes when i drive my break pedal goes soft. i cant figure out why. and usually its at the moments i need them the most. when i hit my break pedal and theyre working fine it sounds like air is leaking out of somewhere a "psssst" noise. now i dont know if it is suppose to do that but i sure as hell know my break pedal shouldnt hit the floor sometimes. any ideas? thanks!
Old Mar 3, 2012 | 02:55 PM
Aune163rd's Avatar
Aune163rd
If you have rear antilock brakes, the sensor will cause this.
Old Mar 3, 2012 | 02:57 PM
hairyboxnoogle's Avatar
hairyboxnoogle
A bad diaphragm in the vacuum booster will make the wooshing sound also, but typically makes the pedal get hard not soft. When the pedal gets soft does it just go to the floor? My old buick does this when low on brake fluid, has a couple leaky cylinders. So i guess start in the most obvious spot and check your brake fluid if you havent.
Old Mar 3, 2012 | 03:09 PM
Aune163rd's Avatar
Aune163rd
x2 with what hairybox is saying(XD...hairybox)
Old Mar 3, 2012 | 03:55 PM
drewdole's Avatar
drewdole
master cylinder could b going bad
Bob10
Sep 25, 2017 11:33 AM
hawncase
Oct 8, 2012 06:29 PM
luckyjoe
Dec 17, 2010 11:31 AM
snaponprofile
33
Oct 14, 2010 12:31 PM
cr506
18
Apr 8, 2010 08:16 PM
