Distributor security lock?
Old Apr 25, 2003 | 11:06 PM
ford2go's Avatar
ford2go
Unhappy Distributor security lock?
Help, I'm trying to pull the distributor on my 88 F150 4.9.
I took out the hold down bolt, but no go -- and Alldata
mentions that there might be a security lock which requires a
Ford special tool. There is a spot under the distributor, which looked like it might have a setscrew of some kind. Looking closer, it'a possible that it might be some kind of small plug. Anyway, whatever it is, it might be the 'security lock'. Has anyone seem this before -- or am I missing something obvious here.
Old Apr 25, 2003 | 11:17 PM
steve83's Avatar
steve83
Does the distributor spin now? If not, it's just gummed in place. AFTER MAKING PERMANENT ALIGNMENT MARKS ON THE DIST & BLOCK FOR REINSTALLATION, twist it free and then pull it out.
I've never heard of a "security lock" on a distributor, but try here.
Old Apr 26, 2003 | 12:47 AM
Boss300's Avatar
Boss300
I recently pulled a distributor from an abused 1980 300. I took out the hold down bolt and it took me 30 minutes of prying and twisting to get it out. The oil was so sludged up that the distributor was basically glued in the engine block, just be careful and pull with both hands and dont break the plastic parts.
GreenMachinee
Electrical Systems/Wiring
Nov 28, 2014 07:06 AM
51f1truck
Dec 14, 2008 11:27 AM
pedrorairez
Jul 22, 2007 03:16 PM
bradplock
1978 - 1996 Big Bronco
Mar 13, 2006 12:18 AM
