Engine Schematic
Old Mar 2, 2012 | 09:49 PM
SARDiverDan's Avatar
SARDiverDan
Engine Schematic
Waiting on a 6.0 cooler to show up and I will just about have everything I need for the big mod/update in a few weeks. Is there a good schematic out there for the 7.3 that shows exactly what plug is what? Instructions that say remove plug "A" is good; however, not really sure what plug is the right one and with my luck I will hook up my FRx or HPx in the wrong plug and all kinds of drama will unfold. Thanks for any help or direction you can point me in....
Old Mar 2, 2012 | 11:17 PM
ChunderDownUnder's Avatar
ChunderDownUnder
scroll down you will find pdf's for HPX and FRX
Riffraff Diesel Performance Parts: Diesel Performane Parts Installation Downloads | Up-pipe installation | Regulated Return Installation and more - Installation
Thanks Roland.
post 2 has a good link for the 6.0 cooler install
https://www.ford-trucks.com/forums/1...oler-link.html
Old Mar 2, 2012 | 11:20 PM
mueckster's Avatar
mueckster
Good job, Brian! Reps to ya!
Old Mar 2, 2012 | 11:27 PM
SARDiverDan
Thanks for the reply. I have instructions; however, some of these photos are not the best and I am not exactly sure what I am looking at sometimes so I would like to find an actual drawing of all of the plugs and exact locations indicating what they are to make the overall process less troublesome. I can probably figure it out once I get in there and start removing things but taking out the wrong plugs has me somewhat hesitant in how this whole process is going to unfold. I read an earlier posting where one of the guys removed the wrong plug and these guys do mods all the time so I would rather check twice and unplug once.
Old Mar 2, 2012 | 11:32 PM
ChunderDownUnder
there are workshop manuals that a very detailed here.
Workshop Manuals - 1999 SD 250-550 - PowerStrokeNation : Ford Powerstroke Diesel Forum
but dont panick m8. just take ya time and follow the instructions. It aint that hard. Have a break, crack a beer open , chew the fat, she'll be right.
Old Mar 3, 2012 | 02:48 AM
woodnthings's Avatar
woodnthings
Honestly it is pretty hard to pull the wrong plug for the HPx or the FRx. The only plug in the area is what you pull.
For the HPx you pull the plugs just aft of the valve cover harness connector. The tube goes under the turbo and to the other side. Pretty straight forward.
For the FRx, the plugs are easy to find. They are square head plugs. The passenger one is at the front of the head and the drivers is at the rear. The passenger side one is often hidden by the wire loom, so just pull it to the side and you will see the plug just forward of the front of the plenum. The drivers side is aft of the plenum just before the up-pipes.
Climb up on the motor with a flashlight and mirror. Grab the instructions and just take a look. You will see it is quite easy really.
Make sure you soak your FRx plugs in PB Blaster or something. That will make them easier to get out. They can be a pain to get out sometimes.
Here are some pictures for you to ponder over.
Drivers Side FRx plug
Passenger side FRx
Here is the HPx location.
Old Mar 3, 2012 | 10:17 AM
SARDiverDan
Thank you for the additional information and reassurance. I had envisioned an array of plugs so I will climb in there and see what I can find. I picked up a couple of cans of PB the other day and figured once I find the plugs; I will give it squirt or two every day for a few days leading up to the install. I will chime back in towards the end of the month with a photo of what it looks like after the updates.
boi_hawks
Modular V10 (6.8l)
Jul 3, 2013 06:41 AM
Furyus1
Jul 14, 2010 09:58 PM
v8xploder
13
Mar 2, 2008 01:33 PM
muscletruck7379
Modular V8 (4.6L, 5.4L)
Mar 25, 2004 07:49 PM
jbulson
Mar 11, 2003 07:43 PM
