Brake controler
Old May 24, 2012 | 11:23 AM
RV_Tech's Avatar
RV_Tech
Originally Posted by Vinford
Im starting to wonder but its Ford factory plugin.
Since the trailer brakes are known to be good, the only way the trailer brakes can lock the wheels is if they are getting full amperage. Unless the new brake controller is also bad, which I think it unlikely, there has to be a wiring fault. My though would be the stop lights, which are not modulated, are feeding the brakes.
I know this seems too basic, but if you unplug the new brake controller, do the trailer brakes operate?
Steve
Old May 25, 2012 | 12:07 AM
Vinford's Avatar
Vinford
Steve
Good question Ill try it
Old Jun 2, 2012 | 09:40 PM
Vinford's Avatar
Vinford
I had a guy tell me I needed a resistor in the hot wire , its getting to much juice all at once?
Makes sense but I dont know?
Old Jun 2, 2012 | 10:14 PM
RV_Tech's Avatar
RV_Tech
Absolutely 1000% incorrect. Ask him why. The brake controller is the modulator for the hot lead and if you wire an aftermarket controller from scratch, the recommendation is that you connect the hot lead directly to the battery terminal as you want an uninterrupted flow of current.
Although brake controllers seem to be complicated, the basics are not and troubleshooting generally takes no more than 15 minutes once folks get used to it.
Steve
Old Jun 2, 2012 | 11:34 PM
Vinford's Avatar
Vinford
It worked fine today when I was loaded , but I went for lunch towing the empty trailer and it locked right up everytime I tapped my truck brakes.
Its embarrasing to pull as the smokes rolling off the tires on a regular basis.
Old Jun 3, 2012 | 04:15 AM
RV_Tech's Avatar
RV_Tech
If the brakes are locking empty, but not loaded, it is a controller issue. It normally means the controller is set too aggressively and needs to be adjusted down.
Steve
Old Jun 3, 2012 | 04:17 AM
RV_Tech's Avatar
RV_Tech
You got a new controller, which one? I want to read the manual.
Steve
Old Jun 3, 2012 | 10:40 AM
Vinford's Avatar
Vinford
The new one is a "Hayes Lemmerz Syncronizer"
#81725
Old Jun 3, 2012 | 11:02 AM
RV_Tech's Avatar
RV_Tech
#81725
This a basic accelerometer controller and Hayes is certainly a reputable company. Not as well known as Tekonsha, but I have visited the factory and their software designed contracts for a number of controller manufacturers so I doubt there is a problem with the control.
Since the only adjustment is the power wheel, I would hook up my trailer and take it to a parking lot and dial the wheel up and down. When you change the power wheel you should be able to feel a difference in how much initial braking takes place with the trailer brakes. Dialed all the way up, the brakes should take hold pronto. Dialed down should be much smoother.
By your description, I would expect the controller is set for a much heavier trailer. For example, on my Hayes G2, which has a digital screen, I set the initial action according to the weight of my trailer in relation to the weight of my truck, so if I set it all the way up, the trailer comes on very hard.
Steve
Old Jun 3, 2012 | 11:06 AM
Vinford's Avatar
Vinford
I have it dialed down as far as it goes.....................
Old Jun 3, 2012 | 11:09 AM
RV_Tech's Avatar
RV_Tech
So the controller setting does nothing? Sorry, I can't recall, is this with your 02 350? And you are connecting your controller using the factory plug?
Steve
Old Jun 3, 2012 | 11:22 AM
RV_Tech's Avatar
RV_Tech
Try this. Locate the brake pin on your seven pin and with no lights, etc. turned on, have someone slowly work the manual slide on the controller while you watch the meter. Doing this overrides any other controller function. Does the voltage slowly rise at the pin? This should tell you if you brake pin wiring is correct.
Old Jun 3, 2012 | 11:57 AM
  #28
Vinford's Avatar
Vinford
It has been wired in.
The truck is the 99 dually.
The gain control works , it really slams on if I turn it up.
Its not the trailer as it works well when I pull it with my 02
Old Jun 3, 2012 | 12:07 PM
  #29
RV_Tech's Avatar
RV_Tech
So the wiring is not off a factory plug. Was it done like this? -
All 1999 and later Ford vehicles without the trailer wiring package:
• The red controller wire must be connected to the light green wire of the brake stop lamp through a 20-amp inline fuse.
• Failure to install a 20-amp inline fuse can destroy the controller and void the manufacturer's warranty.
Steve
billcard
Sep 3, 2014 04:20 PM
bad a$$ roth
All Things Towing
Apr 15, 2014 08:35 PM
jackstraw
Mar 12, 2012 01:13 PM
jleal_21
Aug 17, 2009 10:31 PM
rmosso1
May 16, 2006 07:08 PM
