the toggle is for a manual use of just the trailer brakes only. Should be used if you are having a fishtail or something like that to keep the trailer behind you.
You need to adjust the gain on the controller. Reduce it a bit.
The white plastic switch to which you are referring determines how aggressively the brakes activate and you have to adjust it to compensate for the slope of the mounting position. That is most likely what is causing your intense engagement. The owner's manual showing how to adjust it is online.
This may vary by model. How old is your controller?
Its probably 10 -12 years old.
Trucks only got 30,000 miles on it so it hasnt been used much./
I would pull up the manual and adjust your settings. Controllers are pretty robust and I have used the same model you have in the past with good results.
Steve
Thanks Ill play with it some more.
I dont have a manual the controler was in the truck when I bought it.
The owner's manuals for all the Energizers are online. Just goggle it. Set the gain on top to min and just adjust the white adjuster. If adjusting that does nothing, the controller may well be shot, but that would be very unusual, so I am always very hesitant to blame controllers.
If the controller has the ability to give you gradual stopping manually, it should have the ability to do the same thing when you hit the pedal. If it rips your teeth out when you try to stop the trailer manually, there is something wrong as the controller does not depend on the setting you do with the white adjuster for manual.
Steve
I never tryed it manually I was to busy twisting the **** .
It locked up tight smoking the tires as I tryed to stop at a stop sign with a cop standing there watching me.
So i tryed it again today and think I might know the problem.
I set up everything and got it working a bit better than it was , but I noticed that
my truck brakes arent working very good so the harder I step on truck brakes the harder the trailer brakes come on , making the trailer lock up.
I never noticed my truck brakes werent that good when I was driving around empty.
If that's the case, you WOULD do lots better with a new controller....the one like you have a pendlenum (sp?).... the harder you hit your truck brakes, inerta swings the pendlenum forward.... the new controllers are electronically controlled and are a lot more precise with braking the trailer. Look at the Prodegy, you'll love it.
