97 F150 left rear panel removal
Ok im trying to put my new speakers in the 97 F150 supercab which has only a third door. I had no problem getting to the speaker on the third door, but I can't get to the speaker that is on the non door side. So if anybody knows how to get to this speaker I would appreciate your help, thanks.
Big G
Big G
1. Remove the rear seat back.
2. Remove the seat belt from it's hanging position.
3. If you have a latch window, then remove it.
4. Remove upper rear panel.
5. Loosen top of bottom rear panel and slide seat belt out of the access slot.
6. Finish removing bottom rear panel.
You will need the same tools that you used for the passenger side, and you will also need a 10mm socket wrench to remove the bolts holding the seat back in place. Take your time and look/ feel for screws before pulling on anything to release retaining clips. Hope this helps.
Syncrowave
1999 to 2016 Super Duty
03-02-2016 03:16 PM
makthenif
03-22-2014 03:00 PM
John R. Thomas
17
02-14-2014 01:39 PM
jake_c_19
12-15-2013 09:13 AM
