IPR Removal
Old Mar 1, 2012 | 09:51 PM
mblanken881's Avatar
mblanken881
IPR Removal
What size wrench do you need to remove the IPR?
Old Mar 1, 2012 | 09:58 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Amazon.com: Lisle (LIS68210) Ford Diesel IPR Socket: Home Improvement
bismic's Avatar
bismic
To remove the ipr... IPR socket Tool # 303-769 ($35) - It is 1 3/8 inch.
doh ............ too slow!
Old Mar 1, 2012 | 10:00 PM
mblanken881
Do you have to use the tool or will a 1 3/8" open end wrench work?
Old Mar 1, 2012 | 10:39 PM
mblanken881
If I can't use an open end wrench I'm going to have to bail on the STC fitting replacment. I need the truck by Saturday. I'll just have to do the egr delete and oil cooler replacement and be done with it.
Old Mar 1, 2012 | 10:49 PM
bismic's Avatar
bismic
I really don't know how an open ended wrench would work - it is tight back in there. Since you are removing the turbo, etc, it would probably work. Many people cut a slot in a cheap socket.
Old Mar 1, 2012 | 10:52 PM
mblanken881
I think I'm going to leave it for now then. Truck isn't showing any symptoms of a bad STC. Was just going to tackle it while I was that far in for the egr delete and oil cooler replacement. I'll just keep the new STC for when/if I do need it.
Old Mar 2, 2012 | 05:44 AM
npccpartsman's Avatar
npccpartsman
If you have the turbo out the IPR should come out with an open end wrench just fine. IIRC I used a 15" crescent wrench the first time I removed mine.
LeoJr
Nov 14, 2013 08:15 PM
folsomf250
Aug 31, 2011 09:26 PM
RMoore
Aug 11, 2009 01:21 PM
rwetter
Apr 15, 2006 11:52 AM
dieself250
Feb 28, 2006 05:58 PM
